Question about Toshiba 50H82 50" Rear Projection Television
It take my Toshiba about 10 minutes after I turn it on before the picture is clear? It started doing this about 3 months ago. What needs to be done to fix this?
  • tcostello432 Jan 01, 2011
    Yes, seemed very helpful. An estimated cost for the recommeded action would have been more helpful.
    Many thanks. Looks like I am keeping the toshiba for a little longer.
    Best-
    Tom
  • 10,594 Answers
If you get shaky picture with lots of lines (as shown in below image) in your Toshiba 52H82 tv then it is problem of bad capacitors in Hyper Module, replace these capacitors in hyper module to solve this problem. Hyper Module is little circuit board mounted vertically on signal board and located behind inputs jacks.
Capacitors replacement needs good soldering skills with proper tools, if you do not have soldering parts in circuit board experience, local tv repairman will do this job in proper way.
Thanks.
Posted on Dec 31, 2010
  • Shahid Electronics
    Shahid Electronics Jan 01, 2011
    Capacitors cost $50 plus labor
    Thanks.
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
46'' Toshiba HDTV
It needs the Scan Converter Module repaired or replaced. It usually has dry capacitors that need replacing
Dec 14, 2009 | Televison & Video
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Dec 05, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Toshiba 61 inch rear projection scrambled picture for 10 minutes after power on, then clears up.
If you are seeing lines and or noise for the first several minutes and it goes away--I think I know what the problem is.
Has the period of time before it clears up been getting longer and longer?
Reply to me with the exact model number and I will tell you what is wrong and what has to be done to fix it.
A lot of these sets have problems with what is called a HYPER board----it controls all signal inside the set--confirm Toshiba and exact model number---
I am here to help people and I do this here for free.
REGARDS, SD TECH
Oct 31, 2009 | Toshiba 42H81 42" Rear Projection...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
sounds like a bad capacitor in the deflection circuit.
Mar 17, 2008 | Toshiba 57H81 57" Rear Projection...
Toshiba 42H82 problem
bad capacitors on the hyper module. there are 11 surface mount capacitors that need to be replace and that should fix it. the caps themselves only cost around $14 for all of them together
Jan 05, 2008 | Toshiba 42H82 42" Rear Projection...
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
57"H82 Toshiba-- wavy picture
you got somes capacitor bothering you, and nop, there are nothing you can do, but call a tech, the problem could be in the video card or in the power supply but is a tech job....good luck
Aug 08, 2006 | Toshiba 65H82 65" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Toshiba 50H82 50" Rear Projection Television Logo
921 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
