Question about RCA HD56W58 56" TV
RCA model hd56w58
Cuts on blinks ten times then shuts off will not come back on also i smell a burning smell please help or lead to the right direction
  • 1 more comment
  • jessinat Jul 13, 2008
    Same TV same problem, power button blinks and smell a burning smell. Have you found out anything
  • Anonymous Jul 20, 2008
    Same tv, same problem. I found a component under the screen, easy to get to, that has the part number 1590395a that is burnt. It also had VDE Reg N. 7403 506, 70211506334488, TCE 70234 on it. It resembles a distributor off of on old car, tan in color with a waxy looking substance on the botttom. I haven't been able to find the part on the web yet, Just found it today. Any ideas as to what it is?
  • jddenton Sep 02, 2008
    Same tv, same problem. I found a component under the screen, easy to get to, that has the part number 1590395a that is burnt. It also had VDE Reg N. 7403 506, 70211506334488, TCE 70234 on it. It resembles a distributor off of on old car. I haven't been able to find the part on the web yet? Does anyone have the part number. High Voltage Transformer (Flyback). Part number and maybe a place to buy it? Thanks John
The part number for the high voltage transformer, according to another post for this tv is 258512. See below:
jdenton77
Rank:nonexpert_s.gif Apprentice
Rating: 85%, 1 votes
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv
Posted on Nov 11, 2008
  • waswas284 Jan 06, 2011
    hey guys check this place for the flyback :www. matelectronics.com
Rca hd56w58 burning smell no picture no sound tv want come on
Your TV need a through check-up. Contact any service technician. Burning smell should be due to any short circuited component/s; either its main power regulator section circuit, or, horizontal output section circuit. This is not a user repairable fault, need some practical experience to do repair work. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts
Dec 05, 2013 | Zenith C32V36 32" TV
I love my tv so I hope you can help. It made a high pitched sound, then just shut off and there's a burning smell. Any ideas would be welcome.
UNPLUG SET if you have not done so--fire hazard exists.
I would open rear and LOOK--see what if anything you can see that is burnt---all parts will have a location number printed under or next to them---will point to where problem is---make sure set not plugged in and do not stick your hands inside.
Nov 08, 2012 | RCA HD56W58 56" TV
I have a 52" rca model D52W17. I turn it on and about 10-15 minutes later it just cuts off. Sometimes it trys to cut back on and then goes right back off. I smell nothing burning, screen looks fine when on...
without takeing mesurment i would be makeing a guess = there are some capacitors that could be going bad.. intermetant or delayed shutdown ussally means a overheating or failing component or bad solder connections.
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
Set turned off by itself, power light flashes, and then I smelled something electrical. It will not turn on with remote or manually.
HI, thank you for visit fixya.
Two possibles solutions:
1.--Horizontal capacitor is burn or blown.
Need be replace, located beside horizontal transistor ( .0082uf 2kv ).
Clean the aarea on the chassis.
2.-- Transformer fly back is burn, need be replace.
If you will work on this tv or any special technician will work on this tv, request for replace capacitor on power supply. Common problem too.
Any question. let me know ,please.
Thank you.
Dec 04, 2009 | RCA HD56W58 56" HDTV
Hi! My television was sparking from the back and I checked to see what the problem was. It appears to be a burned out fuse on the tan colored board. Can just this fuse be replaced or do I need a whole new...
As long as there doesn't appear to be any other damaged components on the board, I'd say go ahead and replace it. If it blows again, you know you have a more serious problem.
Oct 11, 2009 | RCA HD56W58 56" TV
RCA 57 inch hdtv Model#HD56W58 has sound but no picture.
WOW...had a high pitch noise, came and went...got worse as time wore on. Would shut off the set, times it cleared times it didn't. Warranty folks set out a TV repairman--said he had worked for RCA exclusively for years...anyway, explained that the 1k hertz noise was a known issue with the HD56W58 and that RCA’s published fix was "nail polish" applied on some board, had something to due with power and vibration...long story "presto" noise gone...but after 6 or so months we began to hear it again—say it ain’t so, but yes the high pitch was back. Same repairman, this time bigger problem...along with noise, the network card is broke and Fry’s Electronics (Irving, TX—hear that Corporate HQ at San Jose…your Irving store needs to be leased in and tote the company line...where's the customer satisfaction???) is balking at a “equal” replacement, they see it as take the less than equal product or get store credit…good luck & wish me luck with the equal replacement they tout when pushing the warranty.
Mar 15, 2009 | RCA HD56W58 56" TV
Channel banner burned into display
All three color lenses may need replaced and if thats the case you might want to consider buying another tv
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns on can hear sound then shuts down.
Did you check the high voltage transformer and the high voltage splitter (distributor). RCA HVT is known for going bad. i have the part number for both if needed. 5520-559-5774 john
Aug 14, 2008 | RCA HD56W58 56" TV
TV shuts off by itself and has a burning smell
mine is doing the same thing but i was able to pinpoint it to a capacitor arching and smoking. haven't replaced it yet so i'm not sure if it's just a bad capacitor or a more involved issue.
Jul 29, 2008 | RCA D52W19 52" Rear Projection Television
Won't power on. Burning smell, High pitch arcing sound,
I have a HD56W58 and it had the same problem. One day the picture went blank and then it made a loud popping sound and smelled like something burning. Now it will not turn on. Has this happened to anyone else? I
Jul 20, 2008 | RCA HD56W58 56" TV
RCA HD56W58 56" TV Logo
692 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
