Question about Plumbing
My Jado 816003 bathroom faucet leaks. How do I disasemble it so that I can fix it? I got the handle off so far.
    Problem Solver:
  • 5 Answers
Assuming I have the right product, My Jado 816003 bathroom faucet - imgres.jpeg (Is this it? 816/003/144) This should help. see step 3
http://www.jadousa.com/assets/documents/jado/install/Install_4040.pdf
Posted on Jan 01, 2011
How to fix a Glacier Bay Bathroom Faucet/ Leonardo
Usually they have a small screw, but its hidden under a cap. Look at the handles you should see a small plastic cap sometimes colored red and blue for hot/cold. Using tip of small knife pop out the cap/plug. The screw holding the handle on is in there.
Mar 20, 2015 | Plumbing
How do I remove faucet handle
Depends on the type of handle. If you have both hoe and cold handles they can usually be removed by prying off the cap that has "C" or "H" on it. Under that there will be a Phillips screw.
Single handle have hex key set screws on the back or under side. Use can back that out with an "Allen" wrench.
Feb 20, 2015 | Jado 842803100 Hatteras Chrome Widespread...
Will replacing a cartridge in my Jado Glance single lever bathroom faucet make the water flow again? It's down to a trickle!
Sounds like you installed the cartridge incorrectly. The orientation is important to note when removing the old unit. Try pulling it out and reversing the orientation. Check the inlets and match them up.
Dec 18, 2014 | Jado Plumbing
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
I cant get handle off my hot water monobloc tap after taking screw out
I am providing the link of the installation instruction for your reference. It seems that there is a lock nut underneath to hold the faucet (figure 1, part 6). http://www.jadousa.com/assets/documents/jado/install/Install_3874.pdf
Feb 15, 2014 | Jado 842/701/105 Hatteras Single Lever...
How do I disassmble a jado kitchen faucet with
you have to locate the water shut off valves before you attempt removing the water lines, hopefully they will be located on the lines under your sink, if not you will have to shut the water main off coming into the house. After you have shut the water off and disconnected the lines, look under your sink at the back were your faucet comes through the sink and you will find the fasteners, unscrew these counter clockwise and the faucet will lift out .
Sep 03, 2009 | Jado 827-850-144 Shogun Single Lever...
JADO BATHROOM SINK FAUCET DRIPS
Jado are ceramic disc cartridges no washers you should replace both sides.You need to remove the handle and unscrew the cartridge
Mar 13, 2009 | Plumbing
Victoria faucet Jado 51.C how to access
Here is a link to the repair parts page on Jado website for your faucet. Exploded diagram shows how the thing goes together...
http://www.jadousa.com/assets/repair/842001_repair.pdf
The handle assembly and collar (8) will thread off after pushed past the limit of the cartridge (gentle consistent pressure)...
In terms of leak itself its hard to say but if the faucet froze from sediment build up and is now leaking it is likely that part of the cartridge is 'clogged' open...
Hope that helps...
Jan 19, 2009 | Jado 842/701/105 Hatteras Single Lever...
Plumbing Logo
274 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
