Question about Acer Aspire AM1640-U1401A Desktop PC
Monitor says no signal..even installed a board mount new graphics card, and tried other monitors
  • Rommel Alilin
    Rommel Alilin Dec 31, 2010
    Have you tried a different computer?
  • agoodguy17 Jan 02, 2011
    I have 5 of them, U found this one in an electronics recycle, bin, fires up great, no beeps, cpu fan goes, power supply goes, drives op and close...un plugged and replugged in the jumper. It says no sognal with each monitor I tried...but I use 2 of them daily, so it's not the monitor!!
    Guru:
  • 2,178 Answers
Remove the new graphics card and use the onboard VGA output from the mother board. Make sure the cable is mounted all the way in - sometimes the connection is loose.
Posted on Dec 31, 2010
No monitor signal on my m2n-vm dvi after installing my new graphics card asus en210.The graphics card was tested on my other pc and works fine..any help?
First boot the computer without connecting Graphic Card, then go to BIOS and find for VGA option change the option to compatible mood, save the setting and come out of it. now off the computer re connect your graphic card and start the computer.
Aug 15, 2012 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Monitor says no video signal, not even from the onboard card. Do I need to get the DVI Graphics-SI card? I didn't get one with this refurbished board. I have tried PCI and PCI Express cards.
1) Monitor plugged into the VGA connector on the motherboard, (Rear Panel), you should get a display.
This is with the proper settings in BIOS.
Reset BIOS back to the factory default settings, and clear CMOS Error Codes.
Unplug the computer from power. (Monitor plugged into VGA connector on motherboard. No graphics card installed)
Press the Power On button in, and hold it in for a count of 5 seconds. (Count 1001, 1002, 1003, etc.)
Let go of the Power On button.
Do this procedure 2 more times.
Plug the computer back into power, wait 1 minute, turn the computer on.
If you get OnBoard graphics now is the time to install the drivers for the graphics card.
Then close all windows, turn the computer off, unplug from power.
OBSERVE Anti-Static Precautions and physically install the graphics card.
Still no?
Time to enter BIOS Setup, and see what graphics settings you have.
(When the post screen comes up press the F2 key)
On the main page use the Right Arrow key to highlight - Advanced - at the top of the screen.
Press the Enter key.
Use the Down Arrow key to highlight - Chipset Configuration
Initiate Graphics Driver should have - PCIE - to the right of it.
This stands for PCI Express. This is the factory default setting.
Internal Graphics Mode Select should have - Auto - to the right of it.
With it set to Auto;
The OnBoard graphics will be automatically disabled when a graphics card is installed.
The OnBoard graphics will be enabled when a graphics card is Not installed.
This is the download page from AsRock Support, for the User Manual for the AsRock ConRoe 945G DVI motherboard,
http://www.asrock.com/mb/manual.asp?Model=ConRoe945G-DVI
On this page click on Click Here to the right of User Manual, after you have chosen what country that is nearest yours.
Allow time for the PDF file to download. (Sometimes up to 30 seconds, and additional time may be needed to fully download the file)
I would also like to know what Power Supply you're using, and if you are sure beyond a doubt that it is a Good unit.
Regards,
joecoolvette
Jun 05, 2011 | Asrock ConRoe945G-DVI Motherboard
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
Nothing shows up in the monitor even the cpu on
Install a new graphics card and plug your monitor into that new video card. Do u get video output? If not, the problem is the system board.If u do, the problem was the graphics card.
Mar 15, 2010 | ASUS P4S533-MX Motherboard
Monitor not reicieving signal
this will work as usaully the graphic card has built in software aslong as u connected to internet the driver will install it self
Jan 13, 2010 | EPoX EP-8KRA2+ Motherboard
Installed the board, scren displays message no signal and stays black. no peeps or beeps. usb has power so do drives and signal leds
Check the cable between your monitor and computer. If this is a new install and you have added a graphics card, you will need to boot up once using the on-board VGA. Doing so will allow you to turn off the on-board VGA in the BIOS. Then you can shut down and move the monitor cable to the new graphics card and reboot.
Dec 05, 2009 | MSI G31M3-L V2 Motherboard
No monitor signal
have you tried checking the monitor to another computer? it could be the monitor?
if not, could be the graphics/video card, or even the motherboard itself could be faulty!
Jun 19, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Monitors wont work
It appears that you have a faulty graphics card.
If the graphics card is integrated with the motherboard then it cannot be repaired. Just purchase a new AGP graphics card, insert it into the AGP slot and connect your monitor to this card.
You may need to go to the BIOS setup to disable the on-board graphics card.
If you don't have an integrated graphics card, then buy a replacement graphics card.
You will need to install the new graphics drivers after installing the graphics card.
Nov 13, 2008 | Gateway 310 S PC Desktop
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
Acer Aspire AM1640-U1401A Desktop PC Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
