Question about GE DCVH515EFWW Electric Dryer
E62 code in test mode ge front load dryer
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Posted on Jan 23, 2010
iwillfixforu
  • 619 Answers
SOURCE: I have a GE front load dryer, model DBVH512EF0WW.
Try unplugging from wall for while and then see if this resets it.
Posted on Jan 29, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a washer dryer
Hi
E62 error code means system contact failure and the user interface board should be checked & replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 06, 2011
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
E62 code on display
E62 - Power relay to heater unit faulty
Could be:
  • Heater unit faulty.
  • Wiring faulty.
  • Electronic board faulty.
At this fault appliance forced cooling cycle.
Dado
Mar 11, 2014 | AEG T57800 Electric Dryer
Error code
E62 = System Contact Error. System contact error is just a fancy way of saying the washer has a loose connection. This connection can be anywhere on the machine, so check all connection plugs by unplugging and re-connecting all connections one at a time. If you don't find a loose connection, replace the control panel.
Read more: http://www.appliancepartspros.com/ge-main-pwr-board-we4m488-ap4980176.html#ixzz2qOlJ8wDy
Jan 13, 2014 | Dryers
Dryer stops and Beeps with Error code E62
You machine needs to be entered to the diagnostic mode, so that you can test the components. But it appears the thermostat or control board is having an issue, and it could because there is lint built up.
Jan 11, 2014 | AEG T57800 Electric Dryer
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
I have error E48 on my GE front load washer
you can down load a file to show you how to put your washer into a srevice test mode
at appliance aid .com in the washer repair aid section line 7 you will see "GE LITTEL SWAN FRONT LOAD WASHER" click on that and you will see two down loads one of them will give you
directions and a list of the codes.
Mar 30, 2011 | GE WSXH208A Front Load Washer
Ge adora problem with panel code e01
I'm almost having the same issues but the code displayed is E62. Can you help
Aug 23, 2008 | GE DCVH515EF Electric Dryer
GE DCVH515EFWW Electric Dryer Logo
118 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
