Question about Sony PlayStation 2 Slimline Console
When i put in game the disc wont spin. i replaced the little black spindle n still same thing. the laser has been cleaned n it slides back n forth but the dic wont spin, need help
    Sergeant:
    Champion:
  • 226 Answers
The motoa is bad when you put the in game the disc wont spin that why. need the be sent out for repair sorry
Posted on Dec 31, 2010
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
Disc wont spin in our play station 2 and lid is closed all the way
Their could be two things:
1. No Spin At All:
2. 1/2 spin:
1. A dirty laser. Try cleaning the laser and see if it helps.
2. An unplugged laser cable. These things normally do not come
3. A dead laser. On models 30001, 35001, and some 30001R, this
Oct 31, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 3 wont read disc can someone help it doesnt read disc at all we have cleaned the disc and nothing is working, someone said the bd drive could be bad if so how do we fix as this is out of...
This could be caused by 2 things
1) The laser is dirty,and needs to be cleaned or
2) more than likely the laser has failed and needs to be replaced
Other than that check the spindle motor by putting a cd in the slot and feel the shell for small vibrations,if you can feel it the spindle motor is fine
If this helps,please give me positive feedback
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont read any disc
Jun 12, 2009 | Sony Playstation 3 (PS3) Console
When i put the game in it says reading then just says open tray and wont read. it used to read after a few try but now it wont work no matter how many trys
Most likely it is your laser lense is dirty. Crack the case get in to the DVD drive open it. While in there give it a general cleaning then clean the laser lense with glass cleaner and a q-tip. Three other things to check. There are three motors in there one slides the tray in and out when you hit the eject button (small hole lower left of metal box under drive) another moves the laser when the tray moves back in you should see the laser move slightly and the lense bob up and down and light up, third is the spinner motor put and disc in the tray and close the tray the disc should spin up if it doesn't then the motor is bad. If all these things have work ok put it back together and test it out.
Mar 23, 2009 | Microsoft Xbox 360 Console
Ongoing Playstation2 Slimline issue
Hi...
The laser wont go on unless the disc is IN and the cover is closed.
There is a disc brake post coming down from the LID . If it's broken , the disc wont spin/read.
The post is on the back right of the LID it (normally) goes thru a cutout that moves the brake out of the way.
Other troubles are debris on the worm gear that drives the laser assembly back n forth.
If the post is broken drill out the old one and put some kind of plastic or wooden stick about 1/4 inch long in it's place
Jan 20, 2009 | Sony PlayStation 2 Slimline Console
I put a brand new game and i wont play i says disc read error
If your other games still work, take the new one back to the store you purchased it from. If your other games are giving you problems then you probably have a laser problem. If you can hear the disc spin, you generally just need to clean the laser lens within the drive. If the disc doesn't even spin, you either have a completely dead laser unit, or a bad spindle motor. Lets just hope it's the laser unit, they only cost like 50 bucks, I don't even know where you could get a new spindle motor. Best of luck
Jul 28, 2008 | Video Game Consoles & Games
Disc doesnt spin , the lens dont move up and down , only lights red
Sounds like a motor issue, not a laser issue.
http://cgi.ebay.co.uk/PSTwo-Slim-DVD-Drive-Snake-Motor_W0QQitemZ290237209741QQcmdZViewItem?IMSfp=TL080609158a11571
That link is for a new snake motor which moves the laser back and forth
http://cgi.ebay.com.my/Playstation-2-Ps2-PS2-Spindle-Motor-V3_W0QQitemZ250083031090QQihZ015QQcategoryZ11328QQcmdZViewItem
This link is for a new spindle motor.
Jun 11, 2008 | Sony PlayStation 2 Slimline Console
PSP GAME
My guess is you used a regular Q-tip to clean the laser lens and it left cotton hairs on the lens. I like to use the foam swabs. You can press the little swtich sticking up inside the UMD compartment. It is on the left and back about 1 inch. When you press it you should see your Laser light up and the spindle spin. This will tell you if the laser and spindlge work. You can physically move to Laser over to the right a few clicks and put the UMD back in it and look to see if the laser moves left and right. if it still does light up, spin the spindle and move left and right, then it probably will need its lens cleaned.
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
PSP
Hi Voltagehog,
You need to look intothe UMD drive. Press the little Black probe sticking up in the UMD drive. It is about 3/4 inch from left and 3/4 inch from top of the UMD drive. When you press it, look for the Disc spindle to rotate, and the Laser to light up and the Laser movement to occur. This will tell you a lot in what is working or not in the UMD drive. If the laser does not move left and right, or light up, you have a problem with the laser. move it manually with a pen or something, Only click it a couple of times. Try the black button thing again. If the Disc spindle motor does not spin. You probably need a new UMD drive.
If you need a new UMD drive, click on "repair directory" at the bottom of this screen, Click on Video game Consoles. Pick out a good service out. I know one of them specializes in Playstations.You can get a new UMD drive replaced for under $60.
Nov 15, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation 2 Slimline Console Logo
69 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
