Question about Jazz DVK141 Camcorder
It will not come on after installing disk and batteries?
  • 890 Answers
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Posted on Dec 31, 2010
  • tyaziat Aug 21, 2011
    okay and how do you reset the procedure from the jazzDVZ 100
New hard disk problem
Unplug , remove battery, reseat the HDD, plug in, reboot. Is the HDD new? If no remove and test.
Mar 11, 2013 | Computers & Internet
My Dell optiplex 210L boots up into a menu that says floppy seek failure strike f1 to continue f2 to run utility
You took your battery out and your computer lost all memory of what components it has installed. Hit F2 to get into the System Bios Setup. Look for your Disk drives and you will see your floopy disk drive there also. You should set the Floppy to Not Installed or None. It is probably set to Auto or 1.44.
Mar 18, 2012 | Dell OptiPlex 210L PC Desktop
Setup is locked, hoekan ik het unlocken om een verse window xp te installeren
OK ..you have several options ...First ..try to open it up ..and remove the bios battery from the main board..remember to also remove any other power source ..and place the battery back after 30 seconds..This will clear the bios settings and also the password..
If this will not work , you can try to fool the system by inserting the disk ..and start without the hard disk on ..It will take teh next option and will boot from the disk ..and you have to plug the hard disk on immediately ..It may work ..
If the password will be removed by removing battery ..than all you have to do is press f12 for boot menu and start from the disk and install .
Another way is to start windows installation from teh previous windows ..Just open the disk and click set-up ..or install windows..it will start from windows and after loading primary files will restart and continue normal ..
the last option is to remove the hard disk and install a clean operation system in another computer and place it back ..
it will work just fine ..but you will need all drivers for your computer to be installed manually and will also need to be made from a boot-able disk ..and not from recovery ..
Anyway ..try the battery removal and let me know what goes on ..and after that we'll see ..
please try to use English ..even if it is not very good...I will try to understand..
Nov 19, 2010 | Dell OptiPlex GX520 PC Desktop
Looking for possible hard drive how hard is it to self install --with windows xp
A few simple steps:
0. find your original Dell "System Restore" set of CD/DVD disks, or order a replacement set from Dell, or run software on your computer to burn a set of "System Restore" disks.
1. do an "inventory" of installed programs (Adobe? MS Office?) and extract any "license-keys" you need (anti-virus software, purchased software).
2. backup your E-mail and contacts and music and other files, either to an external disk-drive, or burn some CD/DVD disks, or copy across your local network to another computer.
3. turn the computer off
4. disconnect the AC power
5. remove the battery
6. remove the old disk-drive
7. determine if it was an EIDE ("parallel-ATA") drive, or a SATA drive, and buy a new drive of the same type
8. mount the new disk-drive
9. reinsert the battery
10. reconnect the AC adapter
11. take your "System Restore" disks, and "boot" from the first disk, and reinstall Windows and the Dell applications
12. run Windows Update repeatedly (Service Pack 3, post SP3 fixes, Internet Explorer 8) to get all the fixes, and the fixes-to-the-fixes
13. install anti-virus software
14. install other purchased software, using license-keys you preserved
15. download the latest versions of "free" software (iTunes, Adobe Reader, WinAmp, et cetera)
16. import your "data" files
OR.................
if both the "old" and "new" disk-drives are SATA, and you have a desktop computer with two "unused" SATA ports, you can use software, such as the commercially-sold "Partition Magic", to "clone" the old disk-drive, and to "expand" the volume to span all the "unused/unallocated" space on the new drive, e.g., copy 20GB from "old" to "new", and then "expand" the 20GB partition to the full size of the "new" disk-drive. Install the new drive into your notebook computer, and enjoy the additional "free" space.
Sep 07, 2010 | Dell Latitude D600 Notebook
Installation of XP MCE won't finish
You need to set the pc to boot from the install disk. Then it should detect the failed install. Either select a new location or over write or format the disk and install.
Trying to recover from a failed install is usually far more trouble than its worth. You usually end up with a unreliable install and nothing but headaches.
Mar 23, 2010 | Microsoft Windows XP Media Center Edition...
Installing windows on acer notebook help
you cannot usually switch installed operating systems from computer to computer like that and still expect windows to boot, but with windows 98 it *might* work.
to install windows 98 on the usb drive, insert and boot from the windows 98 disk like you were to install it on that computer , and then, it should, before it formats any drives, give you a choice of what drive to format.
Oct 09, 2009 | Acer TravelMate 340T Notebook
It's giving me a disk error... A disk error occurred press alt,ctrl, and delete to restart and when i do that some message pops up.
There is a problem with your hard drive. Try taking the hard drive out, remove the battery, push the power button for approx. 10 seconds. Re-install the battery and re-install the hard drive. If the same message comes up again, try to boot the computer off a windows installation disc. If this all fails, you just may have lost your hard drive.
Sep 11, 2009 | Compaq MV 540 15" CRT Monitor
How do I install cordless mouse
if it comes with a disk, insert the disk and follow the on screen instructions, if there is no disk then plug in the USB receiver and make sure the mouse has batteries and is powered on and the computer should detect it and install the drivers.
Jun 14, 2009 | Logitech V220 Cordless Optical Notebook...
Boot problem
Hard disk may be defective, it working intermittently. You can try by replacing a new hard disk.
May 20, 2009 | Dell Dimension 4600 PC Desktop
Hard drive password locked
Have you tried removing the battery, open the reserve battery door, disconnecting cmos (RTC) battery, pressing power button, installing RTC battery, install battery, power up?
Apr 10, 2008 | Dell Latitude D505 Notebook
Jazz DVK141 Camcorder Logo
117 people viewed this question
Top Jazz Video Cameras Experts
mohamed salim shaikh
Are you a Jazz Video Camera Expert? Answer questions, earn points and help others
