Question about Electrolux Freezer Kelvinator Single Door Hardening Cabinet Flash Freezer
My fridge has shut down how do I restart it it is only 18 months old. It is the second time it has happened the first time the technician turned it off and on again. This didnt seem to work from the power point is there a switch on the fridge.
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
Freezer gurgles
    • Give it mouth wash lol
      Check the water valve on the back of the refrigerator if it has an ice maker. Make sure the valve is turned completely on and not constricting the flow of water to the refrigerator via the water supply line. You might also hear a simultaneous buzzing sound when the gurgling noise occurs. In some refrigerator models, this filling process is on a timer, and you might hear the buzzing and/or gurgling every 15 minutes or so.
    • Check the water supply line for leaks or damage. You might see a puddle of liquid on the floor. If air is pulled into the water line as the refrigerator is pulling in water, that can create a gurgling noise. Replace the damaged hose yourself, or contact an appliance repair technician for assistance
      • f he refrigerator to feel a slight vibration. This is probably the compressor processing the refrigerant, which is a liquid. This flow of refrigerant can produce a gurgling sound, and it is normal. However, a simple way to reduce this noise is to make fewer trips to the fridge. When you open the door, you let hot air in, which means the compressor has to work harder (and gurgle the refrigerant more) to cool things back down.
    • Wait while the refrigerator completes its defrosting cycle if you hear water dripping and gurgling in the freezer area. When the heating coil turns on, the melted water from the frost flows down to a drain pan for evaporation to take place. The defrost process usually takes about 30 minutes. This is automatic and cannot be prevented in most refrigerators. Keep the closed to try to prevent unnecessary frost buildup.
    • Wait while the water equalizes in the refrigerator if you hear a gurgling sound when shutting the door. This is normal and is a result of air being forced through the drain tube. The gurgling can last several seconds but should eventually dissipate this usually happens with old fridges upgrade its a good investment
Dec 10, 2013 | Freezers
FREEZER IS NOT FREEZING IT IS 18 MONTHS OLD. WE DEFROSTED IT AND IT FROZE AN ICE CUBE TRAY SO WE MOVED IT DOWN STAIRS PLUGGED IT N AND IT NOT FREEZING AGAIN????
It is possible to cause an air lock when moving an appliance by tilting it and then not allowing the refrigerent to settle before switching on. Try unplugging it and laying it on its side for a couple of minutes, then put it upright and leave it for 6 hours to settle, then plug it in again.
Nov 28, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Frigidaire Fridge/freezer works then doesn't work???
every 6-8 hrs your ref. goes into a defrost mode. sounds to me like your fridge is getting stuck in defrost, may want to replace defrost timer roughly 18-45.00 dollars depending were you live. also ive seen a few that the electrical cord in back were it goes into ref mid way up to the left behind cover can have some loose connections back their; remove panel covering and inspect. becuz if its the timer it wouldnt cause the light not to work so it may not be your timer if the light it turning off.also make sure your outlet is good and the prongs on power cord are not loose. hope this helps
Sep 23, 2009 | Frigidaire Freezers
Hotpoint FFA97 freezer works but fridge does not
It seems to me that there is a leak of gas from your unit.This is if you have 1 compressor/motor)If there is two compressors on unit then it can be thermostat for fridge.Anyhow check if motor is running all the time and is wery hot, if it is there is to little gas in system .This should be covered by guarantee.Jan
Feb 13, 2009 | Freezers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 | Freezers
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
BEKO FRIDGE FREEZER
The best way is open freezer door wait 30 seconds then shut if the door pulls shut further then machine is working if not not working.
Thanks J
Dec 23, 2007 | Freezers
Freezers Logo
44 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
