Question about Philips AZ1010 Cassette/CD Boombox
The piece that holds radio antenna in place is boke . ca it be replaced
  • Philips Master
  • 6,771 Answers
Yes! some tv repairs shop carry them, also Radio Shack supplies various types and sizes, try and match the thickness as close as possible to your boombox.
Posted on Dec 31, 2010
Cd player work but no radio
Assuming the vehicles antenna is intact and in one piece, check the antenna connection behind the radio. If the antenna is connected behind the radio, there could possibly be a problem with the radio's tuner (internally). The only way to properly diagnose this problem is to place a radio that is known to work into the vehicle (simply to test) and check the radio reception. If the radio reception is improved and working, you know the problem lies within the radio itself.
If it still does not work, there is a problem with the antenna on the vehicle (disconnected, damaged, cut, etc.)
Mar 21, 2016 | Cars & Trucks
How do you replace radio antanna
What kind of car is it? If it is a fixed antenna you just unscrew the old one and screw on the new one. If it is an automatic antenna, you can buy either the motor or the mast. Assuming you just need to replace the mast, it comes with the plastic piece with the teeth on it. You need to remove the old broken plastic piece from the antenna motor. You might need to disassemble the antenna motor from the car to get enough of the plastic to grab onto with pliers. While you are pulling on it have someone turn on the radio to activate the antenna up motion and pull the old plastic piece completely out. With the old plastic runner out, the motor installed on the car, and the radio on, run the new plastic runner first through the doughnut screw that holds the mast to the car. Then cram the new plastic runner as far as you can into the hole that leads to the antenna motor. Then hold the very end of the mast (the tip), align the base to the opening as best you can and have someone turn off the radio to activate the down antenna motion. It goes quick so don't have your fingers where they can get pinched as the motor sucks in the plastic and the mast down into the hole. With the mast retracted, tighten the doughnut screw to that the mast won't flop out when you turn the radio back on.
Mar 12, 2015 | Cars & Trucks
I lost the top radial of a Comet antenna model CA-2X4SRB in a carwash - I think. IS THERE A REPLACEMENT for it? Is there a replacement available?
You can easily make your own. I doubt Comet will sell you a replacement. But go to a local cb shop, or ham, radio related place an get yourself a wire to put in socket or mast. I cut down a cb wire antenna an took out the set screw an used my meter to cut it to proper length. Easily done.
Apr 29, 2014 | Comet Antennas CA-2X4SRB Mobile antenna,...
Tundra antenna removal
You will have to un-install the entire antenna system from the inside.
remove the panel carefully adjacent to the antenna system
undo the bolts and clamps that hold the system in place
you can try and install the new antenna piece without disconnecting the transfer wire that goes back to the radio. But usually you will need to get and install a new system.
just to keep you going in the mean time you could just use a old wire coat hanger "classic" just bend the hook straight and shove it in, you have your sounds back.
all the best
Feb 02, 2014 | 2010 Toyota Tundra CrewMax
I am trying to get the front panel of my radio off so i can replace my antenna how do i get the front panel off
That depends on what kind of radio it is. If it has a knob on either side, pull the knobs straight off and you should see a 6-sided nut on a threaded piece, one on each side. You use a socket or needle-nosed pliers and remove these nuts and your radio should come out backwards. I've often pulled the antenna lead right there and put the new on one. You should know it just goes on the back of the radio. If it isn't one with knobs, you'll have to remove screws from the brackets that hold the radio in place. Just look at it and you should see. If this confuses you, get someone who knows that to do, to do it for you...just to be safe. Good luck.
Nov 28, 2013 | 1994 Oldsmobile Cutlass Supreme
Need to replace radio antenna on a 99 isuzu rodeo
I just replaced the antenna on our 02 rodeo. No need to remove radio or anything in dash. This is how I did it.
First you will need access to back of fender, enough room for your hand. Open hood and remove 3 bolts running along top of fender, open passenger door and remove top bolt holding fender. Gently pry top of fender away from vehicle. Place object in gap to hold fender ( I used the head of a rubber mallet). Reach inside fender and disconnect old antenna, follow cable through wall into passenger compartment. Gently pull cable from behind carpet and unplug old antenna from coupler. Connect new antenna to fender ( replacement antenna I ordered was slightly smaller than opening so I had to add washer). Run new antenna cable through wall and plug into coupler. Re-attach fender
Aug 23, 2012 | 1999 Isuzu Rodeo
I have a Midland 1001Z 40-Channels Base CB Radio and a Magnetic-mount CB antenna. 29" stainless steel whip and 6" spring. About 46" high overall. All bought from /www.thesource.ca in Alberta...
Try Grounding it better. Its supposed to equal 8.5 ft.(102 inches) but the coil may make that in all.You can clip like 1/8 inch off at time until it goes 2.1 Swr. Thats a good standard. 1.5 SWR is desired. If it don't have a coil with it that may be the problem. You could turn it into a 8.5 ft. antenna by buying a 102" inch whip to screw into the base of your antenna, it depends if it holds or not. You could build you a matcher like this with a solder gun+solder and 2 resistors. Get you a box with 2 female cb antenna inputs. Drill a hole for both Cb antenna inputs into box. Place them into holes screw nuts down snug. Run a copper wire inside to both grounds or a plate somewhat. Run a thick gauge copper wire from center cb ANT INPUT(2) to other input of ANT INPUT(1). Solder 2 100 ohms in parallel from input to Ground. If you could take apart your radio(eliminating the box idea). Just Solder 2 (100 ohm) resistors to your Antenna output then put it back together. 50 OHM MATCH HERE Is the main idea. I've used 75 OHM Tv coax and reduced SWR.
Apr 04, 2011 | Midland 1001Z 40-Channels Base CB Radio
How do I remove the radio from my 2002 chrysler voyager ?
The one piece face (trim plate) must be removed first. This is a pop off design so be careful to lightly pry up the edges to release...you will need to unplug the lighter etc...Just 4 bolts hold the factory unit in place...after removing these 4 bolts you can pull the radio forward so you can unplug the factory wiring harness...(2 connections) and you should be able to reach behind the radio to unplug the antennae. If you are replacing the factory radio, you should invest in the necessary changeover radio that you are using...For a smooth replacement it is highly recommended to use all of the factory wiring to insure safety, and performance. Hope this helps.
Feb 24, 2011 | 2002 Chrysler Voyager
I need to installl a cd player in my car and i cant get the thing that holds the radio and heater off.
You will have to remove the dash cover to gain access to that bezel piece. That bezel actually extends around the instrument cluster and and radio area, all one piece. The dash cover is held on by a series of torx screws located under the top defrost vent, side access panels (when you open the car doors, there is a panel on each side). In the glove box area and there are two 10 mm bolts that are tucked up under in the glove box area but accessible. After you remove the dash cover, you can remove the torx screws that hold the bezel in place. On the bezel down by the radio, there are spring clips that hold that part of the bezel. Remember when replacing the stock OEM radio, you will need to buy a mounting hardware kit, wiring harness kit and antenna kit for the Cavalier that will work with your new cd player.
Dec 19, 2010 | 1996 Chevrolet Cavalier
I have a electric radio antenna from a 1987 buick regal the nylon string with a metal cable inside used to extend and retract the mast is broke into if i could a new piece i could fix it. walt
Yes it is possible to replace just the mast/antenna part. You just need to goto a car audio place and get an replacement mast. The only other problem is if the the other half of the nylon piece is still stuck in the motor.
Take off the antenna nut that holds the antenna to the car and turn on the radio. The antenna should spit it's guts out, then position the new nylon lead in the same orentation that the old one came out, have an assistant turn off the radio and the antenna should get sucked back in. You need to be somewhat quick when doing the replacement part, sometimes you need to try a couple of times to get the antenna all the way in.
If it doesn't go all the way down there may be a piece of the old nylon string still stuck inside the antenna body.
Jul 18, 2008 | Car Audio & Video
82 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
