Question about Rule 1800 Pool Cover Pump With Leaf Protector 110v
My pump will not pump water off of cover? Is there a safety switch that tripped and I can reset?
  • David Hemming Jan 01, 2011
    Thanks for the help. Looks like I'll have to buy a new pump.
    President:
  • Rule Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Sorry to hear you are having trouble with the pump. Unfortunately there is no reset or other means of restoring your pump to operating condition. If the unit is out of warranty there is no cost effective means to get parts or to have it repaired.
You may be interested in knowing they warranty the pumps for 3 years.
Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
Or Rule direct at www.rule-industries.com.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 01, 2011
Have 3/4 hourse shollow well pump. When I turn more than one thing on such as outside hose and inside faucet, trips the pressure switch on pump, and has to be reset.
The switch you have on the pump with a reset lever is a low water pressure switch that will trip when a load is on the pump like a leak or no water in well and switch will trip to save life of pump. One way to get around this is to install a regular pressure switch and it shouldn't trip out.
Advantage of a low water switch is to save the pump and it constantly triping can be frustrating and I have changed some to put a regular switch in to avoid having to go offen to reset switch.
Aug 02, 2011 | Wayne Water Systems Plumbing
Flipped my 2003 escape onto its passenger side got it back on its wheels drove it away parked then put gas in it and then tired to start it and wont now whats goin on ???
hi.
you may have tripped the fuel pump safety switch. it cuts power to the fuel pump in an accident.
it is normally found behind a cover on the side of the passengers side footwell (possible drivers side on left hand drive). just press the button in to reset it.
if this does not work, you may have to take it to the dealers for them to reset any other safety devices that may have operated.
Jun 14, 2011 | 2003 Ford Escape
I tried my Rule 1800 cover pump to get the spring water off. I plugged it in and it tripped the switch on the outlet. I reset and it ran for about 2 seconds and then quit. I waited a few minutes and...
I assume the device being tripped is a GFCI -- the pump has a short to ground. Most practical solution is to replace the pump. Don't try to run it from an un-protected outlet (no GFCI) -- it's dangerous.
Charlie
Mar 27, 2011 | Rule 1800 Pool Cover Pump With Leaf...
When connecting plug Anti crease/end beeping but nothing else works? WTV 7410 SZA Silverline side and rear
The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
To reset the switch unplug the dryer, remove the power cable and back cover completely. two screws holding back cover are under the top cover which is held on with two screws at the rear. Remove the screws then pull top cover back and then lift it off. Remove last two screws and take off the full back cover . On the front of the motor you should see two white wires going into the safety switch for the belt breaking. Push the button on the left to reset the switch (you probably will hear a click) Do not push the right button as that is what got tripped originally . Good Luck Tim
Mar 04, 2011 | Bosch Dryers
Service repairman says that the 220v not getting to element-found relays on power board black.can these be cleaned to avoid a +$500. repair bill?
I do not know what the problem with the dryer is but if it is it will not run then there is a belt brake safety switch on/by the motor:
if the motor is tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
Feb 25, 2011 | Bosch Axxis WTA 3500 Dryer
Bosch dryer wtmc3300 was overheating and now wont start up. Only makes a clicking noise. The time indicator lights up and thats it.
Dec 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Where is the reset switch on the Bosch 3510 dryer
The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame:
The motor tripped?.
Nov 28, 2010 | Bosch Axxis WTA 3510 Electric Dryer
WTA 3500 vented dryer, the drum does not spin, have cleaned the air inlet/outlets - what now?
Oct 30, 2010 | Bosch Axxis WTA 3500 Dryer
Put sneakers in with towel. Dryer is not spinning. it turns on but doesn't spin. Any suggestions?
if it is a Bosch: The motor tripped..The wiring diagram for the dryer is inside the back cover tie-wrapped to the frame as it sounds like the motor has a trip on it:
Oct 29, 2010 | Dryers
Pump overheated and tripped the safety switch, it will restart for about 20 seconds after you turn it on but then trips off again. I'm thinking it could be the starter solinoid.. how can it diagnose the...
I am thinking the run capacitor is bad, if the motor has a centrifugal swith on the shaft under the motor cover, it could be sticking in the "start" position. This can be repaired with a non-conducting cleaner for the switch..
May 20, 2010 | Emerson Pool & Spa
Rule 1800 Pool Cover Pump With Leaf Protector 110v Logo
350 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
