Question about Kodak EasyShare M530 Digital Camera
It seems to be focusing, but the pictures are blurry - lens is clean, same issue when auto focusing or manual focusing. Doesn't seem to make a difference if I hold the shutter down only halfway to give it time to focus or not.
  • 890 Answers
Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Posted on Dec 31, 2010
I have a canon rebel xsi that is not taking pictures on auto focus. It will take pictures on manual focus, but they're blurry. I changed my lens to a bigger one to see if it was the lens or camera, and...
Try cleaning the lens contacts on the camera body and on the lens.
This maybe the problem, it is not making contact with the lens zoom motor.
Dec 12, 2012 | Cameras
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
I own a Nikon D5000 and am experiencing issues with the 55x200 lens. When trying to take a picture (on auto mode) of an item that is too close, I am hearing a squeaky noise (like the noise made my a VCR...
The 55-200mm lens does not focus closer than 1.1 meters (3.6 feet). If the subject is too close, then the autofocus tries and fails to focus or keeps trying (and squeaking). Either way, you won't be able to take a picture. In manual focus, you can take a picture but it will be out of focus and blurry.
Every lens has a minimum focus distance, closer than which it will not focus. Some lenses focus closer than others. It's a matter of design; making lenses focus closer makes them larger, heavier, and more expensive.
If you want to take close-ups, you have several options. You can buy close-up adapters that fit onto the front of a lens. You can buy a special close-up lens ("macro" or "micro" lens). You can buy extension tubes to fit between the camera and a lens.
Jul 18, 2011 | Cameras
It doesn't allow me to take a shot. On a lense itself, there are two settings A and M. When it it is on M it takes a blurry shot, but on A setting doesn't allow. Please, help me.
M means Manual Focus. If you set the lens to this then you need to turn the lens manually to get it into focus.
A means Auto Focus and when the lens is det to this it should focus automatically but you need to set the mode button OFF Manual. It should work on any other setting.
Jul 05, 2011 | Cameras
Blurry pictures even through the viewfinder window. I've changed settings and nothing seems to work.
maybe its on manual focus. take the batteries out and reinsert them
put it on the green auto program. If that still doenst help the auto focus is damaged
You can also bring it to a photo dealer and ask them how much it is woth if you trade it in. The will discover the issue and tell whats wrong
for free :) as long as you dont let yourself lure of course
good luck
rene
May 27, 2011 | Canon PowerShot SD400 / IXUS 50 Digital...
Have a canon digital elph sd750. Pictures are now blurry.
You could have cracked the lens, damage the focus or a number of other things but the lens and focus are most likely. check your lens for scratches if there is none and no cracks take it to your nearest camera store or buy new good luck!
Aug 08, 2009 | Canon PowerShot A75 Digital Camera
Quantaray 70-300
Sounds like the aperture inside the lens is broken. You shuld send it in for service.
Aug 07, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
My Canon Powershot SD1000 will not focus
You must need to reset all function of auto- focus setting.. its called as master reset. then see its works...
Jun 29, 2017 | Canon PowerShot SD1000 Digital Camera
Every time i take a picture with my nikon d-40 the pictures are blurry. the camera is on auto focus but i can't seem to get the picture to come out clear. any suggestions?
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
Is the AF switch on the lens set to A?
Jun 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Kodak EasyShare M530 Digital Camera Logo
223 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
