Question about Arris SURFboard SBG900 (49402201900) Modem
Home Networking I recently purchased a Motorola Surfboard SBG900. Set it up with Comcast. The modem connects to a ethernet router for my two desktop macs and I also have a laptop. All is well with all computer accessing the internet. But I cannot get the laptop to network/connect to the desktop macs. Scanning does not find them. I must be missing a setting some where. How do I get these machines networked?
  • 1 more comment
  • cneighbors Jul 08, 2008
    No it is a macbook.
    The router is a Vonage device. Motorola V22442-VD. So the set up is cable to Motorola Surfboard Wireless>Router>2 Desktops.
    Laptop accesses the Surfboard.
    ok... thanks... I see the router and settings... but now have no idea what to do to change/edit this... ????
    Confused in Salem.
  • 137 Answers
Buy an air-port Mac router. if that isn't an option what is the model of the "ethernet" router?
Posted on Jul 08, 2008
  • nsindian
    nsindian Jul 08, 2008
    the laptop should have an IP address similar to your desktops for them to communicate. in looking up your devices I saw this:
    http://www.vonage.com/help.php?article=1...
    copy and paste the above link into your address bar. you can then aquire the specific default gateway your laptop needs to connect to and receive an address via dhcp,if the router is set up to be a dhcp server.
  • nsindian
    nsindian Jul 09, 2008
    copy the wireless settings on paper and use those settings to connect the macbook wirelessly.
    ssid, encryption, encryption key, etc ...
  • 63 Answers
Is the laptop an xp machine? If so:
In order to access shared files on a Windows XP computer (or any computer running Samba) from a Mac, the Mac will need to "connect" to the Windows XP computer and "mount" the shared files.
Instructions:
Start at the "Go" drop down menu at the top of your screen, then "Connect to server".
If the computer you wish to connect to is listed, just select it from the list.
If the computer is not listed, type into the "Server Address" field 'smb://' followed by the computer name or IP address of the computer to which you want to connect.
Click the "Connect" button in the bottom right corner of the window. See more at the link below:
http://www.mac-connect.com/win_from_mac.php
I want to plug in another wireless router into my surfboard modem and have the wireless router work as well as the surfboard. Is there a way to do this successfully?
Yes this is possiable. First you need to unplug the power to the Motorola and the new router. Second connect the ethernet cable from the Motorola to the internet port on your second router. This port may be colored in yellow, marked as modem, or the ethernet port by its self. Third connect a ethernet cable from the new router to a desktop or laptop this is only to configure the new router. Next power on the Motorola and wait for the online light to become solid. Then plug in the power to the new router. Give the router about two minutes to obtain ip address from the motorola then try to get on the internet with the pc connected with the ethernet cable. Now you can run the new router setup cd on the wired pc to setup router. Once completed remove ethernet cable to the pc and connect to either network you have and you are good to go. Any questions just ask.
Dec 30, 2010 | Arris SURFboard SBG900 Wireless Router...
I have a Motorola Surfboard SBG900 wireless router and my provider is comcast. Comcast came out and changed some wiring and connections but i continue to loose connection, every couple of minutes. What...
i had the same problem. it turned out the power to the modem was shorting just enough to throw me off and have comcast resetting the ip address and connection. i fixed it by getting a new power supply and plugging it in to a really good strip bar. hope this helps
May 28, 2010 | Arris SURFboard SBG900 Wireless Router...
Motorola Surfboard SBG900 will not connect to Playstation Network
You need to give the PS3 its own IPAddress outside of the firewall. You need to configure the router and the PS3.
Mar 13, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
SBG900 Wireless not detected
See the other post. Change the "channel" on the online settings and that should work.
Jan 12, 2009 | Arris SURFboard SBG900 Wireless Router...
Ethernet Port failure new router
Check the socket in either the router or the PC. I had the same problem, only with my modem. When I inspected the port, the pins were misaligned, causing it to drop a connection. I corrected mine with a screwdriver, which is not ideal but it works.
Jul 14, 2008 | Arris SURFboard SB5120 Modem
Can not connect web cam and view outside of home network
Try to see your modem config and send the data.
regards
Jan 06, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Motorola SURFboard SBG900 loss ethernet connection
Please remove the program of your router and re install it again and it will work..
Good luck
Johnson
Jan 03, 2008 | Arris SURFboard SBG900 (49402201900) Modem
Moto Surfboard SBG900 and VPN Client = SLOW
Please see the specicification, also check with you company
IT Admin, to release it to the Max speed or to check the
net work cable, may be too long, also Test the cable with a Data Test meter and conform the data quality. Or change the port from main router.
Otherwise change the whole networking router.
Regards
Nov 15, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 (49402201900) Modem Logo
453 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
