Question about Garden
Hi,my air compressor silverstorm ac5126 sounded like it exploded last night it had only been used a limited number of times. the pipe that runs from the top at the back to the front with a brass fitting like a nut blew off, it was very dangerous with family standing nearby, it blew off across the room,there appeared to be a small amount of oil under the compressor. I was only pumping up a tyre. Hope you can help me identify this problem
22yooper
  • 828 Answers
SOURCE: Kitchenaid Superba compressor
The compressor relay is located on the compressor under a cover. Before you go to the compressor I would check for other problems that you can see and hear. If the compressor is running there is nothing wrong with its relay.
1. Check the condenser and make sure it is clear and free of dust.
2. If the compressor is cool or cold check for a bad temperature control.
3. Check the freezer compartment for frost on back wall.
Posted on May 30, 2008
  • 726 Answers
SOURCE: 05 golf 1.9D TDI engine code BKC
it will be a problem in the turbo ,
Posted on Jul 17, 2008
SOURCE: Need a part for Homelite model HP3127S pressure washer - 3100 PSI
I lucked out when I managed to locate a local rent it centre who sells and services Homelite equipment. I bought my pressure washer at Home Depot and when I approached staff there regarding my problem, they had no idea if there even was a local dealer who sold/serviced Homelite stuff. telephone enquiries finally led to the rental place who ordered the part for me. I was getting concerned!
Posted on Jun 20, 2009
  • 5655 Answers
SOURCE: The rear suspension is down on my 1999 Ford
I had a 1999 Expedition. When you put the 4x4 on it raises the vehicle an extra inch or 2.
It may help to turn the 4x4 off. Two wheel drive is a lower air setting.
Your original pump may still be good. The problem can be in the front. The compressor is not filling the front suspension to the cutoff point. It will lift the rear after the front end is at running height. Since you lost the front end first, the remaining air bled out there and then the rear came down. Once you shut down the car the suspension was done, all the air was let go.
There are adjustment solenoids on the body but you need someone qualified to repair this.
Posted on Sep 06, 2009
  • 186 Answers
SOURCE: Chain oil is pumping into area where pipe goes
Hello. If you haven't done so already ,remove the bar and chain and make sure the slot in the back aluminum plate lines up with the oil outlet hole if so ok. Use a thin tool (utility knife works) and scrape inside the chain groove of the bar to clean it out.Make sure the oil inlet hole in the bar is clean. If it doesn't work after doing this you may have a cracked oil tank,disconected oil line,or worn out oil pump.
builderdale
Posted on Jan 13, 2010
Testimonial: "Thanks. Looks like pipe from pump broken."
Car stalls when ac or defrost on
Sounds like the compressor is dragging the engine down. The compressor runs in ac and defrost mode. You might try unplugging the compressor to verify.
Jul 21, 2013 | Ford Cars & Trucks
R/v a/c blowing hot air
Will the compressor run? Are the large pipes coming out of the compressor cool at all if the compressor is running? What does the capacitor look like (swollen)? that the compressor and fans are wired to? Was it running OK this year and last year until now? What is the model number listed on the data plate you passed the camera over? Sea Breeze
Jun 13, 2013 | Heating & Cooling
I have a craftsman 919.167241 compressor for about 3 years which is only used ocassionally. used it last week, turned on with around 100 psi in the tank from last use and motor shuts off after about 30 sec...
Hi
Suggestion, in future when finished with air, drain the tank, this may have some effect on the head valves or the pressure switch.
Try disconnecting the head/ tank pressure delivery tube/pipe, run on manual and auto to see whether
it will run.
If there is no air delivery out of the pipe or head.If there is an mimnimal air supply then there may be a problem with the head pressure valves
Hope this is of help
John
Jul 30, 2011 | Craftsman Air Tools & Compressors
Craftsman air compressor wont hold more than 15lbs of air?
Change that coupling . You can try spraying a little WD-40 or similar into it, while you push it open with a screwdriver, just to see if that helps seal it better. If air leaking by there all the time, compressor that small can't keep up.
Apr 13, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
When we are not at our cabin the temp is set to 57. Every time we go there and set it to 70 degrees the furnace will heat for 40-60 minutes and get to low 60's, then I notice hot air is not coming out of...
It sounds more likely that your fan is not pushing enough air across the heat exchanger. If you have a multi-speed fan, I would suggest increasing the blower speed. Otherwise you will continue to cycle on and off on the high limit. Also make sure that you do not have any return or supply vents blocked off, as this often times will cause the same problem. Hope this helps.
Nov 20, 2009 | Heating & Cooling
Possible Contactor Issue
Sounds like a bad fan switch in your unit. That unit has a fan board in it that is time delay on and off. Turn the fan to the on position and let it run all the time. If it keeps temp and does not shut off it is the fan realy board. The board also controls the compressor. Check that first and then the tsat. Russ
Jul 24, 2009 | Carrier 38CKC042 Air Conditioner
High limit switch open- but only faults in night and extreme cold
Hello , I can try to help you out on this one , It sounds like what is happening is that your exhaust vented up is condensating from the heat in the pipe and the cool in the attic or wherever the exterior of the exhaust pipe travels. It is very common because your exhaust/flu pipe is not insulated.
To fix this issue you must drain the water/condensation from the small 5/16th hoses in front of the blower assembly , just pull them loose and angle them downward to drain. This should fix the problem if this is the problem.
Let me know how it turns out or if you have anymore questions. Phil
Dec 31, 2008 | Heating & Cooling
Garden Logo
238 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
