Question about Toshiba Computers & Internet
How do I install addition ram in my toshiba satellite laptop L30 134
    President:
  • 2,653 Answers
  • Shut down your Toshiba L30-10S.
  • 2 Unplug the A/C adapter and disconnect all external devices.
  • 3 Turn the L30-10S over and locate the battery pack at the top edge of the computer.
  • 4 Slide the battery release switch to the bottom right of the battery to release it. Set the battery to the side.
  • 5 Locate the RAM compartment door in the center of the computer.
  • 6 Remove the four screws holding the door in place.
  • 7 Lift the RAM compartment door off to reveal the RAM slot beneath.
  • 8 Lift the clips on the ends of RAM slot to release the current module.
  • 9 Slide the module out of the slot at a 30-degree angle and set it to the side.
  • 10 Slide the new module into the slot at a 30-degree angle and press gently down until the latches lock down and hold it securely. Replace the RAM compartment door and battery, then reconnect the AC adapter and external devices.
  • Posted on Dec 31, 2010
    Accessing bios on a toshiba satellite laptop
    keep holding down the delete button on start up
    that gets to bios
    you will need and external unit with the operating system installed to boot from to get it onto the new hard drive
    May 28, 2017 | Toshiba Computers & Internet
    How can I increase memory of toshiba Satellite A105
    A RAM expansion slot is located on the bottom of the laptop behind a small panel. Remove the panel to get access to the RAM slot/s. It may have two RAM slots, if it has only one the the 1st RAM slot will most likely be located under the keyboard.
    If the laptop has two RAM slots on the bottom of the laptop and the 2nd one is empty then you can add anothe RAM module. Try to get the same make and model as the original to double your RAM..
    If both slots are occupied then you need to replace the existing RAM with larger capacity RAM modules.
    Sep 02, 2010 | Toshiba Satellite A105 Notebook
    Can it support expanded ram - what is the upper limit on ram capacity
    below are the specs for your laptop,
    Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
    Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
    Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
    buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
    May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
    Is it easy to install memory on my toshiba satellite pro 4600
    Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
    You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
    Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
    Thank you for using FixYa.com
    May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
    How do I install additional ram in a toshiba satelite
    There is place under laptop where you add additional Ram.Just remove the bolt and then cover. There are 2 places for Ram.
    Mar 19, 2010 | Toshiba Satellite M115-S3094 Notebook
    After installing an additional 1M of RAM my M55 booted once, then crashed. Subsequently it would not even boot with the new module installed.
    Does it boot with the new module removed? If so, either the new stick is bad, or it is not supported by that laptop. Check kingston.com or crucial.com for specific ram for your specific laptop...then go and get it from newegg or tigerdirect...
    Jan 03, 2010 | Toshiba Satellite M55-S135 Notebook
    What is the max ram for toshiba laptop model #
    Hi Fhiken!
    That modell comes with 256mb rab and supports up to 512mb ram.
    The ramtype on it is SDRAM
    I hope the info helped you
    Nic
    Aug 20, 2009 | Toshiba Computers & Internet
    Adding memory to Toshiba A75-S211
    you buy the memory here for a great price or anywhere online instructions are on the page
    it replaces the 512
    http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Hi there, Just wondering if someone can help me. I just received today two 1GB memory modules so I could upgrade my laptop. Only problem is, It states on numerous sites that my laptop has two memory...
    Here is the link for the Toshiba Satellite M105-S1021 manual. It is zipped and you can download it to your machine. It will tell you exactly how much RAM you can hold and where it is located.
    Please don't forget to rate this solution.
    Jan 09, 2009 | Toshiba Satellite M105-S1021 Notebook
    Memory upgrade
    check the compatibility of the ram.. also,, check the maximum upgradeable memory of your notebook..
    Feb 14, 2008 | Toshiba Satellite A105-S44284 Notebook
    Computers & Internet Logo
    433 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
