Question about Lexmark X5650 All-in-One InkJet Printer
My Lexmark 5650 works fine printing photos off my digicam card but I can't seem to make it print any photos or documents off my computer. I have tried downloading the latest drivers. I can see the printer light up when i try to print a computer document but no printing occurs. USB is hooked up properly. I am using 32bit windows Vista as my OS.
  • 2 more comments
  • timborc Dec 31, 2010
    I think this is bad advice, like told you the printer works fine when i plug in my Digcam card and i can print a photo fine. If the print head was not clean or non-functioning the printer would not be able to print a photo. I have already tried starting and restarting and installing the drivers.
  • timborc Jan 12, 2011
    The problem is not solved as of yet, going to have Lexmark remotely use my computer and see if they can resolve it.
  • timborc Jan 22, 2011
    i got the printer working but it had nothing to do with the information you gave me, I went to the lexmark website and they remotely fixed my computer by changing an icon. Drivers were fine and so were the print heads.
  • 4,924 Answers
Try to reset the printer to the factory settings ..It has to be in the main menu (setting menu ) This will make it default itself it it have an odd setting ..
another thing that you should do is to download the driver and make sure it is the correct one..
It also may be something wrong with the usb cable ..but in this case it will not respont and will not be seen by the computer ..
Anyway you can run the fax and printer from the start ..and complete the wizard..this way you will know for sure it is detected..
the issue I see is that it is recommended for windows XP ..and it may not be compatible with windows Vista ..the driver on the support site is for xp ..anyway ..
I found this one..http://support.lexmark.com/index?page=product&linkSelected=node0&locale=EN&userlocale=EN_US#2
Posted on Jan 02, 2011
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Dec 31, 2010
  • 3 more comments
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Jan 01, 2011
    Hi there sorry for the late reply. If its only problem with computer then i suggest you only one thing, that is go in control panel and select printer
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Jan 12, 2011
    I hope your problem is solved. Just waiting for reply from you .
  • RAJDEEP DUTTA
    ok . I am waiting for further information from you.
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Jan 22, 2011
    Waiting for reply from you
  • RAJDEEP DUTTA
    OK that fine. Thank you for your reply.
How to use photo feature on Lexmark Impact S305
1. From the printer control panel, press the Photobutton.
2. Insert a memory card, flash drive, or digital camera set to mass storagemode.
If document files and image files are stored in the memory device, then pressthe arrow buttons to select Photos, and then press OK.
3. Press the arrow buttons to scroll to Easy Photo or Print Photos, and thenpress OK.
Notes:
• Select Easy Photo if you want to print photos quickly.
• Select Print Photos if you want to customize the photos before printing them.
4. Press the arrow buttons to select a photo printing option, and then pressOK.
Note: You can choose to print the most recent photo, print all the photos,print photos that fall within a date range, print photos by selecting the photonumbers on a proof sheet, or print pre-selected photos from a digital camerausing Digital Print Order Format (DPOF). The DPOF option appears only whenthere is a valid DPOF file in your memory device.
5. Adjust the print settings:
• If you are in the Easy Photo menu, then press the arrow buttons to select thepaper and photo . Press OK each time you make a selection.
• If you are in the Print Photos menu, then press the arrow buttons to selectthe photo , paper , paper type, layout, photo effects, and quality ofthe photos, and to adjust the brightness and color effects of the photos. PressOK each time you make a selection.
6. Press the Color/Black button to set a color or black-and-white print.
When you select color or black-only printing, the light near your choice comeson.
7. Press the Start button.For more info, you can also check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > S300 Series > View User's Guide.
Apr 08, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
What is a scanner and how do i use it on my lexmark 5650 copier?
Hello. The scanner enables you to scan and print photos, text documents, magazine articles, newspapers, and other publications. You can also scan a document for faxing. The scan software must be installed in your computer. Use the installation cd that came with the printer to install the software. Here's an article in the Lexmark website that will show you how to use the scanner. Just click on this link: http://bit.ly/9ShAN7 . Hope this helps.
Mar 25, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My lexmark 5650 printer will print one minute then it want. it says that the document are queue. what does this mean?
The problems means that for some reason the printer is loosing communication or the print spooler is having problems sending the print job to the printer. Here is a very good article on how to resolve this type of issues. http://bit.ly/aYPFtw
Feb 20, 2010 | Lexmark X5470 All-In-One InkJet Printer
Seems to do everything but scan to computer it will scan and print a photo but when I try to scan to computer it prompts, "place document on planten glass" well the document is on the planted glass but it...
Click Start, choose printers and faxes, choose scanners and cameras, right click WIA Canon MP970, click properties, choose events tab, choose select an event, scroll to "attach to email".
Jul 26, 2009 | Canon MP970 Photo All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
No connection to printer when trying to print jpeg files
This is not a photo printer and JPEG are Photo format files.
Feb 02, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Leopard
Sorry the printer hardware is not supportting MAC leopard as printer is old and lexmark dont have driver for mac leopard:that why the printer is not working...
Dec 23, 2007 | Lexmark X83 All-In-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
