Question about HP : HP4 Laserjet Printer
MY HP4 CARTRIDGE IS GETTING STUCK WHEN I WITHDRAW FOR A PAPER JAM. I FIND IT VERY HARD TO RESET THE CARTRIDGE AS IT GETS STUCK RATHER THAN SETTING IN PROPERLY; ONCE I SET IT IT AND START TO PRINT THE PAPER CURLS UP AND JAMS. QUESTION: IS THE CARTRIDGE DEFECTIVE NOW AND CAUSING THE JAM OR HAVE I SOMEHOW DISTURBED THE SETTING IN OF THE CARTRIDGE DO I NEED TO REPLACE THE CARTRIDGE OR DO I HAVE TO A REPAIR TECH REALIGN THE SLOT TO CREATE PROPER INSERT OF THE CARTRIDGE I AM IN CORONA DEL MAR CA 92625 EMAIL DFORD5580@AOL.COM
  • 193 Answers
Well u have to try to insert the cartridges in place before printing cause it may harm your printers health if not inserted properly what i will suggest is that you should watch some videos about how to insert the cartridge for your printer or you should read the manual carefully and if the problem still persist and your printer is in warranty call up the HP people and ask them to replace the printer.
Posted on Jan 04, 2011
Why is there a paper jam from cartridge?
There could be a hard-to-find shred of paper stuck inside. You may have to use a strong light and even do partial disassembly to locate the source of the jam.
Jul 27, 2015 | HP LaserJet 2727NFS All-In-One Printer
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
There's a paper jam in OKI B2400n printer. the manual says to take out the ink cartridge and the jammed paper could be pulled out. Well, the paper is tight and I can't pull it out. What can I loosen or...
You will have to pull hard and evenly to remove the paper. Often, the toner has built up on the fuser rollers, and the paper is actually stuck to the rollers. In that case, you will not be able to get all the paper out, it won't do you any good to remove the paper anyway, because the paper will just jam and stick again. Those rollers will need to be replaced. That is a pretty big, technical job.
Oct 18, 2010 | OKI Office Equipment & Supplies
Paper jam message no paper jam cartridge gets stuck HP 6310 all in one
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | HP Officejet 6310 All-In-One InkJet...
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
Paper keeps getting stuck
see if the paper sensor are jam or if the machine have paper jam.
Jun 18, 2009 | Canon Office Equipment & Supplies
CARTRIDGE JAM - CARRIAGE JAM - PAPER JAM - RESET POWER
change the carrage block will solve this issue.the carrage block cable is damaged
Jun 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Grinding noise/paper jam
Fuser drive gear is a mission to install
Dec 30, 2007 | Brother MFC-8840D All-In-One Laser Printer
Paper jam
Turn printer on,
Disconnected power cord on the back...
Press & hold #, 6 keys while connecting power cord, Keep holding till screen shows reset or shuts down..
Make sure the cartridge access door is closed tightly.
Nisar
Sep 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
49 people viewed this question
Seeker5211
Seeker5211
