Question about Clarion NX700 Car Video Player
Hello there.I have a clarion nx700e how to i update the map data?I have installed the navi extrass tool and i put an empty sd card in my card reader but the tool does not allow me to proceed.It ask me to connect a device.
2 Suggested Answers
SOURCE: Hello! where can I update the maps Clarion NZ 500.
Google "Horizon Navigation Online Shop" and then follow the links to purchase maps.
Posted on Dec 24, 2010
How to access maps on sd card
Same map name on internal memory and sd card can be problem.You can also try to upgrade your software with garmin web updater,but be sure that your battery is fully charged before doing an update.
Jul 27, 2014 | Garmin nuvi 1490T GPS Receiver
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
Application Navi.exe has performed an illegal operation and will be shut down. If the problem persists, contact the program vendor. Program: Navi.exe Exception: 0xC0000005 Address: FFFFCBC0
You have a few corrupted files internally. Contact Rand Support to
obtain a new update SD Card to upgrade you to the new version and maps. The update SD Card will not remove your user
data. Be sure to have your serial number handy,
(back side, bottom right).
Oct 12, 2010 | Rand Mcnally TND 500 Car GPS Receiver
I need help installing a map onto a gramin sat nav
No. They are refering to maps sent from the computer to the Garmin device. Maps are not transferred off the SD card to the unit. Simply insert the SD card into the device and the Garmin will read the maps from the card.
to double check follow these steps
  1. Power on the unit with the card in
  2. Press Tools
  3. Press Settings
  4. Press Map
  5. Press Info (or map info)
This page should list out both your UK and Ireland maps(old as dirt) and your new Benelux and France maps as well
Apr 20, 2017 | Garmin Nuvi 600 Car GPS Receiver
Re: Clarion NICE 430 - how do I update data?
The map data is ready for the upgrade. However, Clarion and the data supplier have been at odds over licencing disagreements. This is ridiculous. The current date for upgrade availability for the NICE 430 is 'sometime' in April. You can call Clarion Canada customer service and they will put you on an email list so that when the upgrade is available, you will be notified. Get ahold of 'Technical Support' at their office at Oakville, Ontario. The phone number is 905-829-4600. Good luck to you!
Jan 29, 2009 | Clarion N.I.C.E. 430 Car GPS Receiver
I need to install map update 2009 data card
If the map is on a SD card, just plug it into the SD slot on the side of your Nuvi with the power OFF. Then turn on your Nuvi and at the main menu, press the wrench symbol, then the map icon and then "map info". Uncheck your old 2008 map and check your 2009 map and you should be ready to go.
- Jim
SHARCNET-USA
Jan 18, 2009 | Garmin Nuvi 660 GPS Receiver
Update for clarion NICE
RAR file 1GB...download load onto 2GB SD card
Dec 18, 2008 | Clarion N.I.C.E. GPS Receiver
Fine drive 400
you will need a 1gb sd card, for the data one solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
Dec 16, 2008 | Fine Digital FineDrive 400 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Kenwood DNX 7100
In order to access the DNX7100's bulit in SD card slot, you have to press the CD/DVD eject button for about 5 secs. It will fold down to reveal the SD slot. This slot is only used for Software and Map updates via a SD Card.
Jan 08, 2008 | Kenwood DNX7100 Car Video Player
Clarion NX700 Car Video Player Logo
224 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
