Question about Refrigerators
Ice cream not freezing. There is snow in the freezer anD the fridge portion is not cold enough
  • 1,772 Answers
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Hi all My fridge freezer seems to have a problem.
increase the thermostat to a more cooler one, ideally at -5 F
Jan 02, 2011 | Freezers
Too cold
If the unit seems to be running non stop, you may have a bad cold temp control. If you have ice cream in freezer, it will likely be rock hard, that you need a chisel to scoop. if your ice cream is ok, its likely not the temp control. On your GE, in the fresh food section, do you have a canopy on the ceiling of fridge, and likely covers the whole top back portion of your fridge? If you do, there is a damper door inside, that breaks off its hinge, and stays wide open, allowing cold air from freezer to constantly be pulled into fridge, freezing food. If you do have this canopy, it will need to be replaced, as you cannot reattach the damper to its hinge.
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator and Freezer are not cold enough
sounds like your fridge is iced up.To cheak this you will need to remove rear panel in freezer compartment and cheak if there is ice buld up.If so you may need a defrost timer or your drain tube may be plugged..If those are fine cheak if your defrost thermostat is ok and not split.Hope this helped:)
May 20, 2009 | Refrigerators
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Freezing problem
I think you mean that milk freezes, etc.
Probably bad thermocouple. In the refrigerators I'm familiar with, there is a thermocouple thermostat in the freezer. There is no measuring of refrigerator temperature; it just gets a portion of the cold freezer air.
If the thermostat is bad, then ice cream should be rock hard too, for it never quits cooling except on defrost cycle, three times per day.
Jun 16, 2008 | Candy CPCA270FFK Bottom Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
