Question about HP DeskJet 940c InkJet Printer
I had paper jam in a HP 940c printer. I removed some of the paper from the front and the balance from the rear. Now I have a flashing orange light which I think indicates a cartridge problem. The print head moved back and forth while I was trying to remove the paper and I wonder if I damaged the print head. I tried new cartridge, but no help. I should have turned off the power.
SOURCE: Bogus paper jam
I had the SAME problem with my printer and after hours of searching on the web I found this solution on fixyourownprinter.com and it WORKED! I cleaned the contacts of both of the ink cartridges and then popped off the cover of the optical sensor on the side of the ink cartridges (black plastic cover over sensor assembly snaps off) there is a hole in the middle of the sensor, push it in with a thumb tack or toothpick and push up on sensor assembly and it will come off the side, clean the contacts on that and reassemble..the blue sensor light should come back on and you should be back in business.
Posted on Feb 05, 2008
SOURCE: hp desk jet 940c
Have I got to use both cartridges,black and the color even while one cartridge is empty.
Posted on Apr 14, 2008
Bubbabear64
  • 2794 Answers
SOURCE: will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Posted on Jun 21, 2008
Nomodo4u
  • 863 Answers
SOURCE: HP 5610 printer won't print
Unplug this beast. Take the old ink cartridge out and re-insert. Also, check for any other jammed papers that need to be removed. Then turn this beast back on. See if that does anything old chap.
Posted on Feb 04, 2010
  • 320 Answers
SOURCE: since removing and replacing the casing to my hp
There is a switch at the bottom of the paper feeder. Check if the switch has been properly set. It will stop the blinking of the paper out.
Posted on Nov 08, 2010
Orange ink light keeps flashing
HP Desk Jet 940c orange light flashing
Oct 01, 2014 | HP DeskJet 940c InkJet Printer
Light flashes 3 times
Which light? Orange? You probably have a paper jam or an obstruction in your paper feed path:
e.g.
Orange light blinking 3 times
1250/E17
Description:
The front door is closed.
Resolution:
Open the front door to allow prints to exit.
1300/E03
Description:
A paper jam has occurred during printing.
Resolution:
Locate and remove the jammed paper from the printer.Press the button on the device to continue printing.
1303
Description:
A paper jam has occurred in the rear tray.
Resolution:
Remove the jammed paper from the rear tray.
Derived from: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Apr 14, 2014 | Canon PIXMA iP3500 Printer
Orange light keeps blinking.How to i fix this?
1.unplug the power from printer to reboot it
2.reinstalling the drivers
3.if the lights flashing like woof said check for jammed paper or sticky label inserts in the back door of the printer.
4.clean the circuit bit of the cartridge (sometimes a thin film of ink can stop the circuit)
Oct 20, 2009 | HP DeskJet 940c InkJet Printer
Orange light is flashing
I cleaned out the printer by removing any access toner. Made sure again no paper was stuck and then it worked.
Apr 14, 2009 | HP LaserJet 2100 Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Check paper light flashes, when paper loaded and no jam present
Might be a pending job gone wild. I would turn off the printer, then go to "Control Panel" and click "Printers". Double click the one you're having problem with, delete all printing documents and re-connect the printer.
You can also try a differnt USB cord or port, otherwise - the machine needs a factory reset.
Oct 22, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP DeskJet 940c InkJet Printer Logo
26 people viewed this question
Seeker5211
Seeker5211
