Question about Ingersoll Air Tools & Compressors
About to install TS4N5 air compressor.....distance from fuse box will be approx. 25 to 30 ft. what size wire should be used to connect the compressor to the fuse box. Will a 30 amp breaker switch carry the load?
    Scholar:
  • 169 Answers
All depends on voltage, horse power of the motor, and single phase or three phase,,, must know that to give you an answer.
Posted on Jan 02, 2011
What size breaker do I need for a Ingersoll Rand Model TS4N5
Look at the motor tag. It should give you the run amps which I believe is about 22. What ever your amps are on the tag multiply by 1.5. If it comes up like my example (11 + 22 = 33) go to the next available size. Like 35 or 40. This should size the breaker to get the unit through start up.
Aug 07, 2011 | Ingersoll Rand TS4N5 Ir Electric...
What weight of lubrication do i use for this compressor...Ingersoll Rand TS4N5? And do I need to bleed the tank off before adding oil?
Yes it is always a good practice to bleed the tank down. there is a check valve in the top of the receiver tank that keeps air from blowing back Thur the system. However if it's leaking you will have pressure on the oil sump. As for type of oil use a 30 weight non detergent oil. Recommend using ir's t30 all season or another type made for air compressor's.
May 23, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Wiring diagram for 230v
Single phase motor for 230V, connect T4 and T5, to one line. T2, T3, T8 common connected. T1 to other line. Check Rotation, This should be for CCW rotation facing output shaft. Swap T5 and T8 for CW rotation.
Jan 17, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Can't get it to come on when it's cold.
Warm it up with a heat lamp, hair dryer etc. Release all air pressure from the tank first. Check your oil and use only compressor oil.
Dec 22, 2010 | Ingersoll Rand TS4N5 Ir Electric...
Connecting the compressor to a tank
You left that question rather vague. Are you asking what material? or What size? I normally would run one size larger pipe size than the outlet on the tank, unless the distance is great. You would connect to the tank outlet which is usually 1/2 way up the side of the tank. Use only black iron or copper pipe, plastic pipe is not strong enough for compressed air. There is some plasic tubing rated for air, but that looks sloppy and isn't inexpensive eitehr. Also put a "FRL" between the compressor and piping (FRL=filter regulator lubricator).
Jul 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Wire size
I used to know all this stuff, the hardware store has a gauge guide to show you the correct size, i would guess that 8 would be ok, 10 would probably do it, hope this is right.
Apr 12, 2010 | Ingersoll Rand Air Compressor Maintenance...
Air compressor line
Three basic methods:
1.Run power to the garage and reclocate the compressor there.
2.Use 3/4" steel or copper pipe run under ground to move the air without loosing as much pressure.
**3. Keep doing what you are doing but...add a portable air tank at the end of the line. I would suggest 11 gallon and add a large diameter 1/2" or 3/4" ID hose that is only 12 feet off of that to reduce the loss of pressure. I even ran a 100 pound propane construction size tank (after cleaning it and refitting it with large diameter pipe) Use a "cross" piple to get air into and out of the tank. Just remove whatever the portable tank has on it and create your own setup. This really works well.
Jun 29, 2009 | Air Tools & Compressors
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
What should be the maximum distance for cooling of airconditioner
Yes, the unit will still be effective. 10 ft. is well within tolerance.
Apr 07, 2009 | Heating & Cooling
Air Tools & Compressors Logo
294 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
