Question about Jandy Laars Lt 250,000 Btu Heater
The pool filter won't turn on and the pressure switch on the heater is blinking
    President:
  • Jandy Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
There is not enough system pressure to close the heaters pressure switch so the heater will not fire or it may be the switch itself is bad but you should first check for system problems that will cause this light to come on.
Assuming your pump is on and any valves in your pipes are set correctly it means something is restricting water flow too much and needs to be cleaned to fix your flow rate and allow the heater to fire.
Start at the skimmer(s) baskets and then the pump strainer basket and finally clean your filter. If it is a sand filter backwash the thoroughly; if it's a cartridge or DE filter, clean it according to your manufacturer's direction. In some cases cleaning a cartridge filter will no longer satisfy heater pressure requirements meaning you will need to replace the element.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 01, 2011
Pressure switch light blinking?
make sure filters are clean then make sure wires are tight on pressure switch then make sure voltage on both sides of pressure switch if not check copper tube to see if plugged
Aug 07, 2013 | Jandy Laars Lt 400,000 Btu Heater
Pressure switch fault on jandy xl POOL HEATER
check to see if pressure switch has voltage both sides also check copper tube to see if plugged
Nov 12, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do you replace a pool heater pressure sensor?
check pressure switch to see if voltage both sides if not see if copper tube is plugged make sure filters are clean
Sep 22, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Hayward h300 pool heater won't start
"LO" is simply informing you that the Heater is not sensing proper water flow through it! A Flow Problem.
A special sensor, called a pressure switch is this source. But... That does not mean it is bad - No, it is in most cases just doing its job!
Most common reason - Dirty Filter.
A good cleaning of the cartridges, or maybe a breakdown and recharge of a DE Filter, or a good cleansing backwash of your sand filter, will remedy this situation.
Or... Check for any OTHER reason or situations water flow may be reduced through the heater:
  • enough water in pool or spa?
  • If you have a weir gate in skimmer, is it stuck in the UP position?
  • Are any valves closed?
  • Do you have a bypass valve at the heater?
    • If open, this will reduce the amount of water going thru heater, close it to the point, LO goes away.
  • Could be debris in front of Pressure Switch, in the copper tubing
    • Unscrew and remove pressure switch, turn pump on. But first, align end of tube so that when water squirts out it will shoot out from heater and not onto electronic heater components!
  • If all above is good, you may have failed pressure switch?
  • Etc
Good Luck - hope this helped.
Sep 17, 2012 | Hayward H-series Electronic Gas Pool...
Pressure switch lite blinks
inside the heater , but hold downd what is the pressure for the filter. that is the anwser low impeller plug or worse line plug high after the filter something is not let the water back to the pool
Sep 05, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars Lt 250,000 Btu Heater Logo
120 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
