Question about Belkin (F5D5231-4) Router
Can not find the PIN code of my router! - Belkin (F5D5231-4) Router
What is the 8 digit pin code of TP-LINK_87524C?
The pin code should be printed on the router itself. Each one is different.
Oct 18, 2014 | TP-LINK Computers & Internet
I need to recover the pin of my router
You mean the pin code to access your internet? There is a reset button that will reset the password/pin to default, but you have to locate the reset button.
Feb 01, 2014 | Computers & Internet
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.
The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.
Here is the link for the Owners Manual for your router..
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Hope this helps..
Nov 03, 2012 | Encore ENHWIN3 Wireless Router
I have a wireless G broadband router. I've had it for quite some time and i dont know where the pin code is or the disk the router came with. how do i find the pin code without the two?
The pin code is normally found on the label on the bottom of your router but it's not mandatory to use it. You can reset your router back to factory and google it's default ip address and it's default password depending upon your brand of router. I would search for D-Link Router default password, default username, and default IP address. On a D-Link router the default IP address would be 192.168.0.1 The default username: admin The default password: leave the password box blank.
Sep 06, 2011 | Computers & Internet
Saying My Pin Code for my belkin g router is incorrect, but i am entering in the correct pin code off the label , so i dont understand why it is saying it is incorrect
There has probably been a change to the pin code. In order to use the default pin code on the label you will probably have to reset it to the default configuration. You can do this by unplugging the router. Find the reset button and using a ball point pen or other sharp object, hold the reset button down. While holding it down, plug the router back in and continue to hold the button down for at least 10 or 15 seconds. You may have to reprogram some of your settings but your pin code from the label should now work.
Be sure to email me back if you have any more questions orif you need any assistance with this solution. Thank you
Jun 20, 2011 | Computers & Internet
When i try to set up my new 3g mobile bbroadband wireless-n router the computer ask me for a pin number that sopposed to be in the back of the router and already try all the numbers that i can found and it...
The PIN number could be the passphrase or encryption key code that is in the router's wireless settings. Go to the wireless router settings for this info.
Nov 17, 2010 | Zoom Computers & Internet
The internet guy was just here today in my new place but i wasn't here with him.To connect to the internet it is asking for a 8 digit pin code located on the bottom of the router. I can seee several...
When you say, "IT is asking for..." exactly what is "it?"
It sounds to me like you have a Linksys wireless interface (possibly USB) on your PC which assumes it is going to connect to a Linksys router, which would have that PIN code on it... but you don't own a Linksys router and therefore the whole PIN code protocol is futile.
Bypass the proprietary PIN code nonsense and enter the WEP or WPA password the installer gave you (if any; it's possible he didn't set any) to connect to your access point from your PC.
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
A pin code does not existed on my router. How do I find it?
Hi friend,
If you turn the router upside down, you will see a six digit number that is the pin code.
Regards
Chiranjeet
Oct 04, 2010 | Computers & Internet
Belkin (F5D5231-4) Router Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
