Question about Viking Cooktops
I have a six burner Viking range. The two center burners (front and back) cannot be used, because the igniters will not turn off once the burners have been lit (they just keep clicking away; sometimes one or both of them will start clicking when I ignite another burner, but not often). My husband has cleaned all the igniter contacts, and has replaced the igniter block. We thought the condition was fixed after replacement of the block, but it recurred after only 1 -2 uses of the burners. Help?
  • 1,998 Answers
There is the possiblity that you have a switch that is stuck as well i had a ge cafe that when you turned on one burner all burners would spark after along process of replacing the spark modulator and every ignitor in the unit i used a voltage meter on the wiring and found that power was going past one switch to the ingitor when the switch had red that it was off after taking the switch apart i had found that on the inside of the switch the mteal contact at one point had arched and was fused to the other side so when you turned on any switch the power would also run through that switch that even though it showed it was off it was still on on the inside of the switch if you are not used to conducting electrical tests on an appliance i would ask that you call a technician this is a very elaborate testing process and should not be carried out by a non trained indiviual if you have any further questions message me back and when we conclude this chat please remember to rank how this opinion has helped as well thanks again
Rick
Posted on Dec 31, 2010
I have a 6 burner range top. When I turn on 5 of the six all 6 spark as they should and the correct one lights. When I turn on the left front knob none of them spark and it will not light, but gas does...
The problem is the burners switch the the single burners has failed, this will cause is not to fire the module and ignite the burner. I would replace just that burner switch to correct the problem. When you call for parts, make sure you have the complete model number and possible color of that burner switch needed. They make or have available switch that are sold by color, so color may be needed for this model.
I hope this helps.
Sep 20, 2013 | Viking 37 in. VGSU161 Gas Cooktop
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
A spark that causes a snapping noise when a burner is turned on.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 26, 2010 | Viking 31 in. VGSU101 Gas Cooktop
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
I hav a Viking professional. Only one burner ignites.
heatman101
Mar 18, 2010 | Viking 42 in. Professional Series...
Same one - ignition click will not stop. Is there a solution?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
wwttw
Sep 25, 2009 | GE 30 in. Profile JGP933 Gas Cooktop
When i use one burner the other one makes the electrical pop
That allows you to light that burenr turn the knob to mid range for the gas on both or full on and it should stop. there is one igniter and 4 burners. Each burer controls the igniter when oven calls for gas.
Aug 29, 2009 | Viking Cooktops
Viking Burners keep on clicking! Anoying!
The causes to the clicking is that the ignitors could be wet, dirty (with grease caked on them or cleaning products or a bad spark module). The ignitors are the little white things on the side of each burner with a metal piece on top. If they are wet (let them dry out for 20 - 30 min on a high flame, if dirty sand the metal piece on top with sand paper or nail file. And if it is the spark module and u are technical, order one from the parts department for Viking. You will need ur model and serial # then find out if it is located under the burners or the rear of the range. There are several wires going to the spark module. Best way is to disconnect one by one and connecting it to the new box until all wires are switched from old to new module. Remember to unplug the unit before doing this because you may get shocked. Also if it is a sealed burner system that means that the burner bowls cannot be lifted from the range and water cannot seap under the burners then you could just change all 4 or six burner bases. Viking has adapted them throughout the many complaints and they are better now. Typical cost is: $350 - $400 if spark module is under burners, in rear = $500 - $600. Burner bases = 400 - 600 depending on number of burners and if it is with a venturi or screws. Good luck.
Aug 23, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Viking stove ignitor
the continues to click problem, for e it was only when my smaller burner was lit. theo others were ok. When I took the burner apart it was very dirty. I cleaned it up (a wire brush in my drill press) and it works fine now. I think it was just bad electrical conduction.
Aug 20, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Cooktops Logo
194 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Ed Mac
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
