Question about Delstar DS 31024 MP3 Player
Will not start
I just placed a new battery in and the only thing that is showing is the word "starting..." What is going on? How can I fix this problem?
Fix this peice of sh--
Posted on Jul 21, 2008
My 1998 Ford Taurus se won't start. First thing that happened was a loss of accelleration, nothing would happen when I press the accellerator. This happened sporadically then stopped. Suddenly the car...
not a different car but a different place to read the fault codes
when there are problems and the code reader will not show them , go to a shop that has a scanner with he right protocols to read the codes
indicates that you have a charging circuit problem
loose drive belt
, problem alternator
problem voltage regulator
problem ECM
problem ground wire or bad terminals
The fix wil be to go to an accredited auto electrician and have the entire charging system checked out
Dec 10, 2017 | Ford Cars & Trucks
I think we may have reversed the polarity. How do I confirm and fix the problem?
Was the battery IN THE CAR when it was being charged? If so, I'd say you might want to call a shop. It may have fried all kinds of things. I've seen cars run with the battery cables on backwards, they just couldn't hook up a car stereo in it...but that was a much older car without the computer components we have now.
About the only thing I would do if it was me, is get a new battery and put it in it, hook it up properly and see what happens. You MIGHT be very lucky. If it won't start or run right, then call a shop...sorry.
Apr 27, 2014 | 2003 Lexus LS 430
2008 Sierra battery problem
You have a parasitic draw on the electrical system . Chevrolet Truck Battery Dies Overnight Part Watch some other videos on finding draw .
Mar 11, 2017 | GMC Sierra 1500 Cars & Trucks
2001 Pt Cruiser. Car died, ran on battery, low lights. radio fade in and out then died. Replaced Altenator, did the same thing, mechanic said bad battery (battery replaced 2 mos ago) their shop showed bad...
have the alternator bench tested for faulty rectifier diode pack
it may be charging the correct voltage but it is AC voltage and not DC voltage
in which case the battery will die quickly
next to check is the voltage regulator
it has to be 4.5-14.8 volts DC and if it in the ECM unit , will require a new ECM to fix
Aug 26, 2017 | 2001 Chrysler PT Cruiser
The 1994 Saturn was started 4 different time then it would not start. The radio and lights come on but when I turn the key it clicks once and that it. This happens each time I tried to start it. Could it...
That would be the first place to check but first clean the cable termanals real good gettin them to shine like silver. The posts too. And it would be wise to remove the ends from the cable if there are two small bolts holding them on and cleaning under there and scraping the copper wire until shiny copper is showing. Then pop the caps on the battery and make sure the water level is a half in down from the top of battery hole. If not add some water until it is and put the caps back on firmly. Lay a rag over the caps before tapping them down to prevent battery water from splashing up on you. Once you have everything clean and back together then try to start it. If no go you will need a jump or put a charger on it to get it started again and then let it run for a while. After 15 minutes shut it off and try to start it again. If it does then you should be good to go. If it don't you have a bad battery. This may have started the car and all seems well but one more test will need to be done and that is if it will start in the morning. If it does you have it fixed and Yippy Friggin Skippy!!! But if it does not then you have a bad cell and it drains over night. The only thing left to do is take the battery into walmart and use it as a core to get a 15 dollar core refund towards your new battery. If you don't shop wally world then try for a core charge refund where ever you do shop. I wish you the best and please leave me a thumbs up for trying my best to save you a few bucks. Let me know how it turns out, Your new best friend, Razzy
Apr 20, 2010 | 1994 Saturn Sl
Ok so we've placed a new gas cap in service on our 2001 Dodge Grand Caravan and we still show a P0455 code. What is the best place to start now?
The best place to start is with a full visual inspection of the fuel lines/hoses to make sure you have no leaks. The next thing will be to replace the purge solenoid. When they go bad they will show code P0455 along with others sometimes.
Oct 15, 2009 | 2001 Dodge Caravan
Aug 06, 2009 - I DID PUT NEW GAS IN IT ALSO WHEN MY BATTERY WOULDN'T JUMP START AFTER A FEW DAYS I PUT IN A NEW BATTERY AND MORE GAS,AND IT STARTED UP FINE FOR 1 1/2 DAYS THEN WITH THE NEW BATTERY CAR...
well i really do not no your isuses is what dose the car really do it dose not start or dose it run or what if the car sit around a lot you could use fuel stabilzer sea foam work grate and good cleaner for Eng you can get it at most car place now is the battery dead every time you come back to car is this the isuse need more info to help ase tech
Aug 06, 2009 | 1996 Chevrolet Blazer
Ford aerostar clicks but will not start
Could be two things. Older cars have problems with a build up of resistance in the ignition circuit this can cause the car not to start. The fix for this is a new ignition switch (the electrical part not the key part) or your battery is either going dead or is very weak. Charge the battery and see if that helps. Be aware, if your maintenance free battery is more than 5 to 7 years old, it should be replaced.
Nov 13, 2008 | 1992 Ford Aerostar Extended
Something is wrong
sounds like a battery problem or a power problem. Best thing to do here is send back to creative or contact on line.
Apr 10, 2006 | Creative Labs MuVo Slim MP3 Player
Delstar DS 31024 MP3 Player Logo
44 people viewed this question
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
