Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
My pump has seized-up from working to hard i.e. not stopping or turning itself off. I replaced it with another and everything was just fine, then again, it wouldn't turn off or on unless I mannually did it myself. Not the thing is dead again. What am I doing wrong>
  • 3 Answers
I'm going to suggest that your pump(s) have the same symptoms of cardiac failure and you're bleeding out. the pump is trying to keep the pressure in the system. it works but you're losing your prime is my guess. the pump is initially fine and tries to maintain its pressure but cannot. it runs until its hot or burns out. and then it dies.
Posted on Aug 01, 2013
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: I replaced old pump w/
The water and therefore the pressure has to be going somewhere. If you are sure that there are no leaks in the house or outside, then the water is going back into the well. There is a check valve either in the suction line of the pump between the top of the well and the pump or down in the well.
If this check valve fails, it allows water to go the wrong way and back to the well. The result is that you lose pressure.
Secondly, you have to be sure that there are no air leaks between the top of the well and the inlet to the check valve. Leaks in that piping will make repriming difficult.
Write back with more and I'll try to help more.
Gary
Posted on Jan 22, 2011
My Gould pump has been working fine for 2 months now has stopped pumping. Now when you turn it on it hums for 30 seconds and then kicks off. It has water in it so don't know what the problem is.
pump impeller jammed ,motor bearings seized,motor seized ,short in pump windings if 208 possible lost a line feed --need to check power and pump to see if turns
May 30, 2017 | Cars & Trucks
Water cooler stopped working
Compressor seized, may just need a new start relay or capacitor
Aug 07, 2012 | Haier WDNS32BW Hot Cold Water Cooler With...
When pump is plugged in it makes a humming sound, then trips the GFI and everything stops.
The pump is seized up meaning that it cannot turn....try taking the cover off and spinning it by hand and then retrying it...
That may work if not then it has gone bad and will need to be repaired or replaced...
heatman101
May 10, 2011 | Leader Clear Answer 2 Pump
My car was running perfect until the guy change the 3 spark plugs located in the front of my car.the back has never been change yet. so afta that he also change my low beams on my headlights,i had already...
Check the all the pulleys to see if any are seized, they should all turn freely, and your car belts shouldn't squeel at all ( loose belt, worn belt, bad steering pump), don't know what your talking about the brake fluid, did your low beams work before ? if so then why would you change them ?
Dec 30, 2010 | 1996 Buick Riviera
Have a 97 honda civic, hard to steer.repaced p/s pump
hard to steer is not the pump in most cases, it is the power steering rack and pinion steering gear.
May 05, 2010 | 1997 Honda Civic
My Admiral washing machine won't agitate. It made a few "popping"sounds, then stopped agitating. It still spins fine and drains fine.
either a transmission or a seized motor lift the front off of the machine remove the water pump and try to manualy turn the motor if you can turn it then the tranny is bad its not hard to replace but get a manual for the step by step
Nov 17, 2009 | Office Equipment & Supplies
The pool pump is not turning over, there is power but it sounds like the motor is seized
If you have current and a ground, power wise your fine. You need to check and make sure there is no clogs in the lines causing the pump to fail. If you have no clogs and the pump sounds like it is trying to work, it probablly is seized up and needs replaced.
Oct 02, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Power steering box and pump
Try a different grade of oil.Sounds like the oil is the wrong grade.
Jun 07, 2009 | 2002 Oldsmobile Intrigue
New Electrolux FL washer - will not fill with water
There are three main possibilities here. Firstly there may be a blockage that is stopping the water from flowing. Secondly there may be an item stuck in the pump chamber. Lastly the pump itself may be seized up. On machines that have their waste pipe connected under the kitchen sink it is always worth checking that the plumbing is not blocked with fat or lint at this junction. Check for kinking of the waste hose, this may of course release itself if you pull the machine forward. As for blockages and obstructions inside the machine itself it would be difficult to give any real guidance as there are so many models. If the pump is seized or defective the solution is nearly always the replacement of the whole pump.
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
167 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
