Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
I have a toshiba 52hm84 green light blinks 10 but the red lights steady i change the lamp still same.no picture
    Genius:
  • 1,622 Answers
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
Posted on Jan 01, 2011
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Green light stays on red light blinks set won,t go on but bulb does not look blown also fan does not run after tv is shut off like it use to before and tv shuts itself off after a while when it does work...
With a dim picture even if lamp looks ok I would make it suspect number one---going to have to decide if you want to buy a new lamp to find out--average life is 1-2 thousand hours.
Apr 23, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
Repleaced lamp on Toshiba DLP 52HM84... still wont turn on. It goes through the auto start up 8 times and still no screen. The red and green lights blink at the same time. What does this mean?
The fault is indicative of the lamp circuit, check the lamp fittings, check the power circuit and the ballast.
If the voltage insufficiency is present from the power supply it can lead to low current and thus the lamp will not power up. Also if the replaced lamp is faulty, not of original quality or if there are connector issues, this must be rechecked.
Check all the connectors on the power supply side and the motherboard. remove and reconnect.
Oct 13, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
When I turn on the TV the sound comes on but there is no picture. It turns off/on automatically several times then the green and red lights blink with no sound.
this is common problem for rear projection TV set's you have to replace the BULB after a approx. time of 2 years I found the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=52HM84
Sep 17, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Dec 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 52hm84
Search "Ballast replacement for Toshiba 52HM84" on your favorite web serach engine
Oct 25, 2008 | Televison & Video
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Sep 15, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
445 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
