Question about Epson DFX-9000 Matrix Printer
Dfx9000 dfx 9000 gives error o3 intermittently.......pl help any one knows about it
  • Anonymous May 07, 2009
    it gave me guidance
    there is a brake sensor just below the head ul see a laser light just adjust the ribon back ro the slot... n u done
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Posted on Aug 04, 2009
  • Epson Master
  • 691 Answers
The SP motor brake signal did not switch on within 3 seconds after turning the printer on.
Check, and if necessary replace, the following in the order below.
1. Check for disconnected SP motor-related connectors (ROM BOARD: CNSPHS, CNSPM)
2. Check the Interlock switch, and if necessary replace the switch assembly
3. Check both the SP motor and driver. (Always check both.) Check fora broken fuse on the SP motor 42 V line.
Replace the motor assembly and/or ROM BOARD as necessary.
Posted on Jul 23, 2008
Dfx9000 error03
Its a carriage load measurement errors. Get it repaired by technicians.
Ford Performance Parts
Aug 17, 2012 | Epson DFX-9000 Matrix Printer
Epson printer dfx9000 problem ribbon jam errorr i change the ribbon cartridge and test in another printer my ribbon is correct but in this printer this error is shown yet what should i do?
Check for any foreign objects that could be affecting the ribbon cartridge assy ,clean and reset ,perform a maintenance check via the printer menu
Feb 03, 2011 | Epson DFX-9000 Matrix Printer
I've got an error 3 in dfx9000
I'VE GOT AN ERROR 16 IN DFX-9000
Sep 14, 2010 | Epson DFX-9000 Matrix Printer
DFX 9000 Printing problem
when i switched on epson dfx9000 printer its showing Error 01,Pls give the solution.
Dec 17, 2008 | Epson DFX-9000 Matrix Printer
Dfx9000
Internal hardware detects that the paper paths do not switch during paper path switching operation.
Check HCPP sensor or call for service.
Phone Number:
(562)276-4322
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
EPSON DFX9000
The error code and the lights indicate a fatal error inside the printer. Actually, this is for service already so you need to check the warranty of your printer or call EPSON. I would like to give you some idea on what's happening with your printer. This is something to do with the LES or the left end sensor is not beginning detected. It is when you turn the printer ON/OFF or during normal operation that the left end position is not reaching where the sensor signal should be detected. There might be a need to replace a part of the sensor and its connector or the ROM BOARD itself. Again, please check this with EPSON certified service center.
May 23, 2008 | Epson DFX-9000 Matrix Printer
Error 0E
head driver error:
chk carrier cable unit
worst ROM Board = service
Mar 12, 2008 | Epson DFX-9000 Matrix Printer
Error 16
Dear Rashid,
I understand that this errors occurs in POST mode. You can always refer to service manual or troubleshooting guide of your machine upon purchase especially it displays error code. However not all error codes are not servicable for ordinary users due to risk. To give you an idea in solving the problem; present this error code to authorized service center and offer them to purchase the defective parts regarding this error, or you can troubleshoot by detaching or removing running parts one at a time. We'll see if the error changes. Contact me if there are progress, I can help you pin-point the problem somehow I can resell parts soonest with this type of printers.
Best regards,
Rosener Guyano
Jan 27, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
605 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
