Question about Cell Phones
Changed nam1 to nam2 on samsung sch-r410 now it wants initial programing and a key code
  • Anonymous Feb 26, 2009
    I have the Alius and the same thing Happened to mE!
Well by now you probably already solved this problem. This is for future references of anyone else who come across this. The steps are easy and simple.
1st, dial #43574357*
2nd, u should be at a device info menu. select system info.
3rd, your password is the last 4 digits of your MDN number.
now u can access your phone and change back to NAM1
Posted on Feb 06, 2009
The only thing you can do is call your provider and have the give the num lock to your phone because its all different codes....good luck
Posted on May 07, 2009
Switched to NAM2 and do not know the lock code.
Dial *22899 and press SEND to program the phone.
after it has finished downloading the programming information, the phone will reset.
The Lock code will now be set to the last 4 digits of your phone number.
when you have finished, be sure to switch back to NAM1 and dial *22899 again to re-program it.
Sep 30, 2009 | Samsung SCH-u740 Cellular Phone
Unlock my Samsung!!!
enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to
Sep 05, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Stupid code
If you can switch to nam1, that is your active phone number. If its asking for the code first the code will be 000000 or 0000
Jul 31, 2009 | Samsung SCH-u740 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Initial programming needed
Dial *228 and press send. Listen for the prompt and press 1 to program your phone. Remain on the call while your phone is programmed (could take up to 2 minutes). Do not hang up until you hear, 'Your phone has been programmed successfully."
Apr 22, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
Jul 06, 2008 | Samsung Glyde SCH-u940 Cellular Phone
Trying to unlock my samsung r410 fone
type *2767*3855# this is a hard reset and this will correct it
May 31, 2008 | Samsung SGH-D900 Cellular Phone
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Apr 03, 2008 | Samsung SPH-M500 Cellular Phone
Cell Phones Logo
626 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
