Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Hi. Just got a new Jazzy Select 6 Ultra, with the seat lift. Only now am I finding out that the seat lift raises the minimum height of the seat so much that I can't fit under a normal size table. I have looked online for complaints about this issue but found none. Am I missing something?
  • 280 Answers
Bruce,
There are several approaches to a solution tof the problem you are experiencing.
This chair may have a standard van seat or rehab seating. A standard van seat looks like an SUV seat and a rehab seat has a custom seat and custom back. FYI, the Jazzy Ultra 6 specification for the seat actuator is 4 inches of stroke or elevate.
If you have a van seat the cushion will be too high in its lowest position.
If you have a van seat the vendor can switch it out for rehab seating. Rehab seating is a seat pan (flat plate) with a cushion set on top of it. By varying the cushion thickness you can raise or lower what is technically called the seat to floor height measured from the top of the cushion to the floor. This is what you describe as the minimum seat height.
If you already have rehab seating, you might try a thinner seat cushion, going from 3" to 2" with a denser material.
The chair frame and actuator dimensions are locked in so this dimension cannot be altered. On some occasions, I have been able to remove some top actuator frame plates, but this will only help with about 1/4" of height and substantially weakens the seat to top of actuator mounting. Sometimes this reinforcing plate will be on the bottom of the actuator in the battery box frame.
The chair can go back to the factory and a custom modifications to the seat frame can be made. This is always easier and more cost effective on the front end at time of order of the chair. An inquiry would need to be made to Quantum (Pride) to see if this is even possible.
You may also be able to get a Motion Concepts custom, i.e. shorter actuator (less than 4 inches of stroke). This will also decrease your elevate to less than 4 inches.
Your provider and an experienced rehab tech can come up with some viable solutions. Hope this helps.
Posted on Jan 02, 2011
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
Power indicator indicates fully charged. Speed control indicator led's flash continuously. chair runa at 1/4 speed. What needs to be done to get it to run properly and stop flashing.
You may need to take to a Pride dealer to plug the diagnostic unit in to check for faults. Have you got a power seat lift on the chair. When the seat is up (or not fully down) the drive speed is limited so you wont tip over. If the seat is down fully and still have problem, it could be the down micro switch needs adjusting or is faulty.
Jun 08, 2015 | Pride Mobility Products Jazzy Select 6...
What will replacebattery charger 2904jt24
Hi IF U GO TO E/BAY THERE IS A SCHAUER PARTNo JAC0724 charger suitable for pride jazzy select 6 COST US $139 GOOD LUCK
May 12, 2014 | Pride Mobility Products Jazzy Select 6...
I need a wireing diagram
Hi, you find all the information you require clicking on the link below.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Regards
GeWiz.
Feb 26, 2013 | Pride Jazzy Select 6 Ultra
Hi I purchased a used jazzy 1103 for my father and need to replace the batteries I cannot remove the seat directions say pull friction lever up to remove seat however the seat won't move
the seat post is probably rusted in the post. Try lifting the handle and twisting the seat and pulling up at the same time it can really be very hard but keep trying and maybe get some help to lift as it is being turned. I've had to use a hoist to lift it off the floor and twist the seat until it comes out. Hope this helps
Feb 22, 2011 | Pride Jazzy 1103 Ultra Standard Power...
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Sep 30, 2009 | Select Products Power Chair Pride Jazzy...
The power lift seat on my wife's Jazzy 1103 Ultra won't actuate.
most actuator motors have an in-line fuse, I think the one for pride 1103 is located under the cover at rear of chair or close to actuator motor
Mar 15, 2009 | Select Jazzy Used Electric Wheelchair
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
324 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
