Question about HP Pavilion m7100y (PX189AV) PC Desktop
I have an HP M7100Y Media computer runnign XP and replaced the cooling fan but when I boot I get an error message System Fan Failure press F2 to continue. How do I avoid the error message?
    Brigadier General:
  • 8,909 Answers
Does the fan spin up? There is a third wire on the fan that is interogated by the uProcessor to determin how fast it is spinning. If it is spinning but not registering, there is an interface problem, maybe poor connecion on the socket it plugs into?
Hope this helps.
Posted on Dec 31, 2010
How do I check the CPU cooling fan setting in the BIOS please ? I also understand my PC has a TV tuner - how do I access it please ?
On startup push F2 (or DEL or F12) to enter setup/bios.
As for the tv tuner, you'll need to connect Cable TV to it then use some software such as Windows Media Center, to view the channels.
Oct 16, 2014 | Dell (6F858) Cooling Fan
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    When the computer boots up. It makes almost a grinding noise and I get an error msg, saying the fan is failing. But it does boot up by hitting f2 which is one of the options after the error msg. The other...
    The only resolution other than replacing the fan by sending the PC to repair, is to clean the fan.
    Power Off the desktop
    Open the side pannel using the thumb screw or the philips screwdriver
    You will see two fans in the unit, one on the processor heat sink (CPU Fan) and other on the back (System Fan)
    Try to clean the fan by blowing air using a hair dryer or a vacum cleaner (in light mode)
    Put back the side pannel
    Power on the PC to check for error message
    If it's still there, you need to replace the fan if it wont allow you to pass through using F2
    Regards,
    Shrey
    Jun 01, 2011 | HP Compaq Presario SR1830NX PC Desktop
    MY PRINTER hp laserget 4250 dtn is displaying 57.4 error when I turned it on, what can I do? I am ofetn requested to suitch off and then to switch on but it fails to mark " Ready"
    57.4 Main fan error
    Hi I hope this will help
    The text come from the hp manual
    good luck Ian
    Q2431-90912 Chapter 7 Troubleshooting 287
    57.X
    PRINTER ERROR
    To continue turn off then on
    or
    57.3
    EP FAN FAILURE
    or
    57.4
    MAIN FAN FAILURE
    A printer fan is not functioning.
    X Description
    3 EP cartridge fan, right side
    (LJ 4300 only)
    4 Main cooling fan, left side
    Turn the printer off and then on.
    57.3 Cartridge fan error (F2)
    1. Reconnect the connector
    between the fan and the
    DC controller PCA
    (location J78).
    2. Replace the fan. See "Cooling
    fan (right side;
    HP LaserJet 4300 series
    printer only)" on page 170.
    3. Replace the
    DC controller PCA. See
    "DC controller PCA" on
    page 181.
    57.4 Main fan error (F1)
    power supply.
    2. Verify that the ribbon cables
    are fully seated in the
    connectors on the
    DC controller PCA.
    3. Replace the fan. See "Main
    cooling fan (left side)" on
    page 168.
    4. Replace the power supply.
    See "Power supply" on
    page 188.
    5. Replace the
    page 181.
    57.7
    DUPLEX FAN FAILURE
    The cooling fan in the optional
    duplexer is not functioning.
    1. Turn the printer off and then
    on.
    2. Replace the duplexer.
    Mar 25, 2011 | HP LaserJet 4250dtn Printer
    57.03 error
    57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
    1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
      • x = 1: FM1 (Laser/Scanner Fan)
      • x = 2: FM2 (Power Supply Cooling Fan)
      • x = 3: FM3 (Formatter Fan)
      • x = 4: FM4 (Face Down Deliver Fan)
    2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
      • Fan 1 J208
      • Fan 2 J216
      • Fan 3 J210
      • Fan 4 J225
    3. Replace the faulty fan motor.
    Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
    System fan has failed
    Your system's fan has failed. If it is under warranty, you need to have HP made aware of this failure.
    Jun 18, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
    HP Pavilion m7100y (PX189AV) PC Desktop Logo
    147 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
