Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung 50' DLP Tv. Is it a lamp?
I have Samsung 50' DLP tv with lamp BP96-00677A(P). I was watching my tv when all of sudden I hear small explosion sound and distinct burn smell. No picture. Is it a lamp?
    Champion:
  • 217 Answers
There is a lamp door in the back for end users open it up and check it out, could be the color wheel exploded also
Posted on Jul 18, 2008
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
What is causing my picture to darken on my samsung 60 inch dlp tv
Most likely the tv projection lamp life are ending.The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on watches like 4 or 5 hours each day?The tv projection lamp life are ending,require a new tv projection lamp.
Jan 04, 2011 | Samsung HL-S6767W DLP TV
TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
May 03, 2010 | Samsung HL-S5086W 50" HDTV
Samsung SP50L6HX, I replaced the Lamp but still nothing.
Hi, Samsung haves a known issue with the ballast, once you make a replacement of the lamp, sometimes its harder to ignite a new lamp that has 100% of gas inside than igniting a old lamp that has maybe 60% or 50% of gas inside. Just in order to ignite the lamp, the ballast needs to send some High Pulses of Voltage, as high as 15 kV (that is the constant clicking sound that you are hearing). In order to resolve this you need to change the Ballast Board. I tried to look for your ballast with your TV Model # at samsungparts.com , but nothing showed up. You will need to find out which ballast part # you have in order to find it online. To locate the ballast part # please check the end of this video, you only need to take the lower back cover of TV off. http://www.youtube.com/watch?v=0jr_9A5Xd2Q
Here is a link of a ballast I found http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1138231.htm?Click=49915
Dec 24, 2009 | Samsung SP50L6HX 50" DLP HDTV
My samsung dlp tv sp50l7hx had to bemoved to lay
although the lamp may look ok your tv has all the signs of lamp fail they only need a slight bang. I know that it is cheaper to replace lamp than light engine
Nov 08, 2009 | Samsung SP50L6HX 50" DLP HDTV
Picture suddenly went out and the lamp and temp lights in front circle are blinking.
Hi,If your tv is between 2-4 yrs most likely it's time to replace the lamp.If you hear continuous clicking it could be the ballast which is the board that powers the lamp.If you hear buzzing it could be the color wheel,which is a spinning wheel that creates the color on your tv.God bless you!
Oct 13, 2009 | Samsung HLN4365W 43" Rear Projection...
Tv turns off after watching an hour - then proceeds to turn off every 15 to 20 minutes there after
Hi if your tv is a DLP or LCD and you hear clicking or like wanting to turn on ,most likely its an issue with the ballast which is the board that powers the lamp.(Discard if tv is )If you hear buzzing or spinning noises it could be you color wheel.Also check if fans are running ok or if they are dusty, clean them with an air pressure can if they are dirty.It could also be time to replace the lamp.they normally last 6000-8000 hrs if it's a Philips brand if it's na Osram lamp they will last 4000-5000 hrs 1-2 yrs.God bless you!
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Jul 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Lamp Light On
you will need to replace the lamp.
Mar 23, 2008 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
182 people viewed this question
Jerry Greenberg
Jerry Greenberg
