Question about Lowrance LGC-3000 GPS ANTENNA FOR UNITS (042194530055)
What can I replace my LGC-3000 with? I guess it has been disscontinued.
Toshiba error e010
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%20556&code=E010
Quoting from link above:
Code
E010
Description
Paper not reaching fuser transport sensor: Paper which has passed the fuser unit does not reach the fuser transport sensor.
Remedy
Open the jam access cover. Is there any paper on the transport path or in the fuser unit? ? YES ? Remove the paper. NO Is the fuser transport sensor working? (Perform the input check in the test mode: 03-[FAX]OFF/[7]/[C]) ? ? NO ? 1. Check if the connector of the fuser transport sensor is disconnected. 2. Check if the connector CN332 on the LGC board is disconnected. 3. Check if the connector pins are disconnected and the harnesses are open circuited. 4. Check if the conductor pattern on the LGC board is short circuited or open circuited. 5. Replace the fuser transport sensor. 6. Replace the LGC board. YES Is the transfer belt working? ? ? NO ? 1. Check if the connector of the transport belt is disconnected. 2. Check if the connector on the transport motor driving PC board is disconnected. 3. Check if the connector CN341 on the LGC board is disconnected. 4. Check if the connector pins are disconnected and the harnesses are open circuited. 5. Check if the conductor pattern on the LGC board is short circuited or open circuited. 6. Replace the transport motor driving PC board. 7. Replace the LGC board. YES Is the drum separation finger solenoid working? (Perform the output check in the test mode: 03-111,161) ? ? NO ? 1. Check if the connector of the drum separation finger solenoid is disconnected. 2. Check if the connector CN339 on the LGC board is disconnected. 3. Check the installation state of cleaner. 4. Is the relay connector connecting the cleaner unit and the equipment disconnected or stained with toner? 5. Replace the drum separation finger solenoid. 6. Replace the LGC board. YES Is the registration sensor working? (Perform the input check in the test mode: 03-[FAX]ON/[4]/[E]) ? ? NO ? 1. Check if the connector of the registration sensor is disconnected. 2. Check if the registration sensor is installed correctly. 3. Check if the registration actuator is operating properly. 4. Check if the connector CN341 on the LGC board is disconnected. 5. Check if the connector pins are disconnected and the harnesses are open circuited. 6. Check if the conductor pattern on the LGC board is short circuited or open circuited. 7. Replace the registration sensor. 8. Replace the LGC board. YES Is the registration motor working? (Perform the output check in the test mode: 03-108/158) ? ? NO ? 1. Check if the connector of the registration roller clutch is disconnected. 2. Check if the connector CN341 on the LGC board is disconnected. 3. Check if the connector pins are disconnected and the harnesses are open circuited. 4. Check if the conductor pattern on the LGC board is short circuited or open circuited. 5. Replace the registration roller clutch. 6. Replace the LGC board. YES Check if there is any abnormality in the space between the registration motor and the registration roller (metal). Check if the registration roller (rubber) is rotating smoothly. Check the condition of the registration roller at the horizontal transport section and clean or replace it. * If the error [E010] caused by a paper jam underneath the drum cleaner often occurs due to an insufficient paper separation from the photoconductive drum, set a smaller value in the code 08-841, and see what happens. At this time, however, pay attention to the transferability at the leading edge of the paper since this transferability can be slightly narrowed depending on the environments and conditions under which the equipment is placed or the media type of the paper used. (Refer to 3.6.1 in this manual about the details of the code 08-841.)
Mar 22, 2018 | Toshiba Office Equipment & Supplies
How to Problem detect & Solution for Toshiba e-Studio 232 Error Codes E210
Lower drawer transport jam (Paper not reaching the
registration sensor): The paper does not reach the
registration sensor after it has passed the 1st transport
sensor.
Open the transfer cover. Is there paper in front of the registration sensor?
?? YES ?? Remove the paper.
NO
(Perform the input check in the test mode: 03-[FAX]ON/[2]/[A]
llllllll
NO ?? 1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN305 on the LGC board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are
open circuited.
4) Check if the conductor pattern on the LGC board is short circuited or
open circuited.
5) Replace the registration sensor.
6) Replace the LGC board.
YES
Are the (lower/middle) transport clutches working?
(Perform the output check in the test mode: 03-203, 205)
lllllllll
NO ?? 1) Check if the connectors of the (lower/middle) transport clutches are
disconnected.
open circuited.
open circuited.
5) Replace the (lower/middle) transport clutches.
YES
1) Check the condition of the feed roller, separation roller and pickup roller of each paper
source, and replace them if they are worn out.
2) Check the transport roller. Replace it if it is worn out.
Nov 16, 2017 | Toshiba Office Equipment & Supplies
Toshiba photocopier solution error code E030
Open the cover of the unit/area whose picture is blinking on the control panel. Is there any paper on the transport path? (Refer to the following table.)
IF Yes Remove the paper.
No 2
2 Is the sensor in the
jamming area working?
IF No • Check if the connector of the sensor is
disconnected.
• Check if any of the connectors on the LGC
• Check if the connector pins are
circuited.
• Check if the conductor pattern on the LGC
• Replace the sensor
• Replace the LGC board.
3 LGC board • Replace the LGC board.
Jun 11, 2016 | Toshiba Office Equipment & Supplies
How to clear eror code CE90 in toshiba 305 machine
Drum thermistor abnormality,
(1) Check if there is any abnormality on the connector between the equipment and the process unit.
(2) Is the harness between the LGC board and the drawer connector for process unit disconnected?
(3) Is the harness inside of the process unit and the harness of the drum thermistor disconnected?
(4) Is the connector CN310 on the LGC board, or the connector of the drum thermistor
disconnected?
(5) Replace the drum thermistor.
(6) Replace the EPU memory board.
(7) Replace the LGC board.
May 18, 2016 | Toshiba Office Equipment & Supplies
Toshiba E-Studio 3511 Color Copier code cea0
[CEA0] Revolver home position detection abnormality
Is the revolver home position sensor working properly? May need to be cleaned.(Perform the input check: 03-[FAX]ON/[2]/[C])
NO 1. Check if the connector or joint connector of the revolver home position sensor is
disconnected.
2. Check if the connector CN361 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the wires of harnesses are
open circuited.
circuited.
5. Replace the revolver home position sensor.
YES
1. Check if the conductor pattern on the LGC board is short circuited or open circuited.
2. Replace the LGC board.
Oct 26, 2011 | Toshiba Office Equipment & Supplies
Error code "CA10"
Hi how are you this is jack .....(jack_pak@hotmail.com).. my personal ID.
Laser optical unit related service call
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
Misfeed in copier error E200
Hi how are you this is jack my personal ID
Paper transport jam
[E200] Upper drawer transport jam (not reaching the registration sensor)
Open the jam access cover. Is there paper in front of the registration sensor?
YES Remove the paper.
NO
Is the registration sensor working? (Perform the input check:
NO 1. Check if the connector of the registration sensor is disconnected.
2. Check if the connector CN345 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the harnesses are open-circuited.
4. Check if the conductor pattern on the LGC board is short- or open-circuited.
5. Replace the registration sensor.
YES
Are the upper transport clutches (high/low speed) working?
NO 1. Check if the connectors of the upper transport clutches (high/low speed) are
disconnected.
2. Check if the connector CN362 on the LGC board is disconnected.
5. Replace the upper transport clutches (high/low speed).
YES
1. Check the condition of the feed roller, separation roller and pickup roller of each paper source, and
2. Check the transport roller. Replace it if it is worn out.
Thanks
Best Regards,
It says gps not responding
check both baud rate and port that has been set.
please rate my help++++Thanks for using FIXYA
Jun 11, 2010 | Lowrance LGC-3000 GPS ANTENNA FOR UNITS...
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
Lowrance LGC-3000 GPS ANTENNA FOR UNITS (042194530055) Logo
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
