Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 82V522
The water won't get hot on model 81v52s 50 gallon. is there a rest or how to diagnose.
The reset button is located behind top panel on water heater.
If you have some hot water, then reset is not tripped, and tank has different problem.
I suggest a complete 30-minute troubleshoot using multi-meter from hardware or home center.
When test calls for checking voltage, rotate multimeter dial to 240-250-277 VAC
When test calls for continuity or testing elements, rotate multimeter dial to Ohms
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Follow troubleshooting steps from top of page to bottom, and water heater if fully repairable by homeowner.
See label on side of tank for wattage of element.
Second two digits on Rheem serial number are year of manufacture.
Shown below are Rheem 4500 Watt element and Generic upper thermostat.
Add a comment if you need more free help.
Also take advantage of fixya phone service.
For a price, fixya expert walks you through repair steps over the phone.
Posted on Jan 01, 2011
  • Anonymous Apr 26, 2011
    The troubleshooting on link above are fully tested and accurate. The element shown is not necessarily Rheem. Open panels on side of tank to see if element is bolt-in or screw-in type. Both types are available at home center or hardware.
I have a new AO Smith Electric Hot Water heater. When I turn on the water, at any of my sinks, or my shower, it's very hot for a minute, then it turns lukewarm.
Your water heater may not have been installed correctly. You should get hot water shortly after you turn on the faucet. There may be a defective heating element or temperature controller. Also, the 50 gallon tank may be too large for your application.
Oct 10, 2016 | Water Water Heaters
I have a Rheemglas Fury Model #81V52S C, MFG date 05/2003, 50 gal Does not heat properly--not long enough. I Cannot find a gauge, or know how to adjust tempeture--hope that is only problem--please...
One of the elements may be bad. With the power off check each one with an ohm meter. Should show continuity.
The tube the cold water come in through goes to the bottom of the tank. If it has come loose and the cold water stays on the top you wouldn't have much hot water.
Jan 01, 2011 | Rheem Water Heaters
If my 50 gallon water heater is leaking can i replace it with a smaller water heater?
There should be no problem replacing a 50 gallon heater with a smaller size heater as long as the codes for your city/town allow it. You may also need to pull a permit for the installation, check with your municipality. Some codes state that a home with X square feet or whatever measurement they want to go by, will need at least a 50 gallon hot water heater. Obviously all installation instructions and codes apply to any new hot water heater installation.
Sep 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
50 gallon electric heater not working after about 5 minutes in the shower the water gets cold and the rest of the house i do have 240 going to water heater thermostats goood element good
Some elements will read with a meter good until they heat up.
Hot water then going to ice cold top element is working and bottom bad. Luke warm water and then goes cold bottom element good and top element bad.
Elements and thermostats are not to exspensive to replace.
If you have power only two thing's left are the thermostat's and the elements.
May 21, 2010 | Water Heaters
Rheem electic water heater model 81v52s. Switch was tripped off. I turned the switch back on. Will the water heat now?
providing ther is no problem with water heater it should.
It it trips again check out thremostats on heater.
May 15, 2010 | Rheem 81VP6S/430126 Water Heater
Extreme hot water then to consistent luke warm
Possible thermostat problem. Are you experienced enough in that area to do some testing. Have a multimeter? If not experienced, don't try it, too dangerous. Call in a service person.
Mar 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
We have a 83 Gal. Rheem 41V50 40,000 Btu - What do we replace it with? It is leaking
The model number you gave is for a 50 gallon tank, not 83 gallon.
50 gallon ones are readily available, including the same model..
Oct 20, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 82V522 Logo
738 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
