Question about Minolta Dimage Scan Dual Path-Through Scanner
Have misled the pci scsi card for this old scanner, i wanted to try and resurect it using XP but dont know the type of card i need, i think its a 50 pin i still have the scsi cable and i think you would call the end that attaches to the scanner as male,any help would be very much appreciated...R
  • Minolta Master
  • 1,381 Answers
How do i use an epson filmscan 200 with a laptop running windows 7
were you using it under windows xp? if you have 32 bit windows 7 I would try those same drivers. Unfortunately the filmscan 200 came out under windows 95/98 and so Epson never released XP drivers and some people were able to make it work.
I would consider connecting it to an older computer running windows 98 and then transfer the files as you scan them (this would definitely be the least painful)
If you have 64 bit windows 7 I would not even waste the effort, 32 bit is a long shot maybe.
Do you have scsi drivers on the the windows 7? because the filmscan 200 is a scsi 2 device
Good luck
Nov 24, 2010 | Epson FilmScan 200 Film Scanner
Can you pls. suggest which PCI Xpres card support Fi-5530C2 Scanr
Hi Karthik,
Please click on the following link for recommended SCSI cards for your Fujitsu Fi-5530C2 scanner .
http://www.fujitsu.com/global/support/computing/peripheral/scanners/scsi/
Please revert for further clarification.
Thanks & regards,
TechSatya
Jul 26, 2010 | Fujitsu Office Equipment & Supplies
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Jan 04, 2010 | Dell PowerEdge 2600 Server
Umax astra 1200s with windows XP
This particular scanner is a nightmare to get working with XP
When it does work it is also prone to random errors.
On the UMAX australia site I found the information I needed to make it actually waok at all.
Below is part of a very old email that I went through with Umax maybe that will help you ?
It is quite an old scanner though.
Sorted out by steps as follows. Disconnect scanner usb lead from computer / hub 1. remove ALL umax software as issued on the cd and any upgrades 2. shut down restart 3. run norton (not the one button but the win doctor) to clean up any loose ends (important but dont know why ? does not work unless this has been done ??) 4. shut down restart. DO NOT connect scanner 5. Install software from original cd 6. do any umax software upgrades (ALSO IMPORTANT ) 7. shut down 8. plug scanner back in. 9. power everything back up 10. do new hardware wizard thing 11 swap driver to correct one as per instructions on your site somwhere ? all working I just did the norton one button on a second machine and it did not work so did all steps again but used norton win doctor as per step 3 and all good it worked a treat on two machine so it appears repeatable.
Sep 11, 2009 | Umax Astra 1200S Flatbed Scanner
Adaptec AHA-2940 UW PCI SCSI CONTROLLER
If you are using Windows XP, the drivers are embedded. It will automatically recognize the SCSI card. For other OS try http://www.adaptec.com/en-US/support/scsi/2940/AHA-2940UW/ S. Mohan.
Jun 09, 2009 | Canon Office Equipment & Supplies
I need info on the make of scsi card that is bundled with scanner
It may be an old Adaptec SLIM-SCSI series. Very popular on Late 90s
1. Adaptec PCMCIA Fast SCSI Controller ( 1807600 ) - SCSI Controller ...
    "Adaptec Storage SCSI Controller Card, Storage 1807600, Adaptec PCMCIA Fast SCSI Controller."
    www.superwarehouse.com/Adaptec_PCMCIA_Fast_SCSI_Controller/1807600/p/88814
2. Adaptec SlimSCSI 1460 review - IT Reviews
    "Adaptec is the king of SCSI connectivity devices and currently offers two PC Card (PCMCIA) SCSI cards. The 1460 is the jack-of-all-trades model, ..."
    www.itreviews.co.uk/hardware/h82.htm
3. Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0 ...
    "Download Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter 5.0.2183.1 - Adaptec SlimSCSI 16-Bit PCMCIA SCSI Host Adapter."
    www.soft32.com/download_171850.html
Jan 18, 2009 | Umax PowerLook 2100XL Flatbed Scanner
Trying to resurrect my FS2710 Scanner.
I found the disk that came with the FS2710 scanner and tried loading the drivers. They are not XP compatible. My solution is to not invest anything in this scanner, buy a new scanner, and sell this old one on ebay.
Dec 22, 2008 | Canon CanoScan FS2710 Film Scanner
Microtek scanmaker 35t plus
Throw the scanner away and replace-
Scanners used for DOS based systems [Win 95/8]
Wont work with NTFS systems[2000/XP/Vista]
Aug 19, 2008 | Microtek ScanMaker 35t Flatbed Scanner
How do i connect a "fujitsu 4750 scanner to my PC.
my pc does not have a 50pin connector. so i need (i Guess) a converter that will go from the 50 pin to a usb on my pc?
thanks.
May 28, 2008 | Kodak Digital Science 3520DP Path-Through...
New motherboard not compatible with scanner.
http://www.mustek.de/eng_/html/treiber/scsi/scsi16.htm isa
http://www.mustek.de/eng_/html/treiber/scsi/scsi32.htm pci
I think you only need to download the driver. in the device manager, the card should come up as an unknown device. I f the card doesn't show then it may have fried too :(
Feb 27, 2008 | Mustek PARAGON 1200 SP Flatbed Scanner
Minolta Dimage Scan Dual Path-Through Scanner Logo
99 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
