Question about Thermador 1400 CFM Remote Ventilator Model - VTR1400Q Kitchen Hood
Our Thermador cook top have been used with the Thermador blower VTR1400Q for 11 years (exterior wall mount). After he recent heavy rain and wind for one week (California), the blower now is barely run or not at all. When it rund (motor run much weaker than normal), it last for a few minutes then shut off by itself. We suspect the blower is bad, so we need to replace it? How much does this cost? Thanks, Tim
5 Suggested Answers
  • 52 Answers
SOURCE: Thermador Blower Motor Not Starting
to check capacitor disconnect power to unit. remove wires coming from the capacitor making sure to note where they were connected. Using the ohms setting on your multimeter place one lead on each of the two post. Watch carefully and if the capacitor is good your meter will spike for a second then return to zero. IF nothing happens capacitor is bad. Good luck. Kevin
Posted on Feb 01, 2008
  • 5 Answers
SOURCE: Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Posted on Jan 07, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a Thermador 'Cook
Ok the problem is the switch I just looked at the install manual and you only have 2 wires to get it to work. Once you replace the switch it will be working fine. you can get the switch on the link below.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=233265
Posted on May 01, 2011
oldTech2332
  • 2341 Answers
SOURCE: Do you know the dimensions
this link is for the installation manuel is has all the dimensions
http://www.ajmadison.com/ajmadison/itemdocs/Care_&_Use_Manual_19-12-182H.pdf
Posted on Jul 21, 2011
Hood has a remote blower (VTR1400Q). Only working on MED and HIGH setting.
See if it has a blower motor resistor(controls speeds) and replace it.
Look up model at repairclinic.com & see it the resistor is a listed part. See link, go to repair help by model number. Forget it. I just checked the only part they sell is the motor for $267. You can buy a new hood for that.
May 16, 2016 | Thermador PH48ZS Kitchen Hood
I have a 5 Burner Thermador gas cook top SGS305FS and if I am cooking something on the middle burner, and turn on the other burners to cook something else, it seems to take a long time for the other...
You need to have the gas pressure read after the gas valve while in operation to se that the manifold pressure is not below 3.5" wc for nat gas or 11 " wc for propane.
Apr 16, 2014 | Kitchen Ranges
1999 Blazer air/ water leak top forward corner
i've had leaks like this and they are hard to find,my solution is close all doors and windows turn on your heater blower to high and take a tablespoon of liquid dish soap and mix with water and then use a paint brush to apply and go around the windows and doors with this solution if you see bubbles you have found your leak, then you can fix the problem,hope this helps.
Sep 16, 2009 | 1997 Chevrolet Blazer
I have a old wall built in thermador toaster & need parts
I have a Thermador built-in toaster ( new in box). It has never been used but I have had it for many years. Willing to sell.
Mar 29, 2009 | Kitchen Appliances - Others
Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Feb 19, 2009 | Thermador SGS36GS Gas Cooktop
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Waterleak passanger foot well after rain
lift the bonnet and remove the plastic trim below the windscreen (passenger side) this covers the pollen filter check for distortion this will be the problem. replace the pollen filter it will be damp.if the trimis not too distorted refit or buy new. The trim acts as a rain water gutter and has been fitted incorectley, have you recently had a service ?
Dec 11, 2008 | 2000 Ford Focus
Looking to buy highly reliable double wall oven
Well in my professional opinion if I only had those two to chose from I would go with the Thermador unit Why ??? From a service point the parts are readly avib. and the replacement parts cost is less then the Dacor. from my recent repairs the Thermador is more of a heavy duty unit as far as the most options I think Daycor has it beat. I own Gaggenau units and love to cook as you it is just what I wanted. Just remember you get what you pay for and the best match is the unit that will give you the options that are most important to you Hope this helps.
Feb 12, 2008 | Thermador SEC302 Electric Double Oven
Kitchen Ranges Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
