Question about Nintendo Wii Console
Will not come on when plugged in to the tv but we have a second one that will when plugged in the exact same way.
    Problem Solver:
  • 17 Answers
Try getting a diffrent tv
Posted on Dec 31, 2010
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a toshiba 32c100u tv i dont see exactly were to plug all white and red wires
red and white colored plugs are for audio, red it right channel and white is left. Plug your DVD player (if that's whay you have) into the red and whte on the tv, some tv's only have one audio in and its usually white, in this case plug in only the white wire from your player. the yellow plug is for video and you should plug that into the yellow jack on your tv. If you tell me exactly what you are trying to plug in I can help you better.
Mar 16, 2011 | Toshiba 32C100U 32 in. TV
Power turns off after a few seconds
Hi
With a plasma TV the more likely culprit would have been the high voltage generation. Replacing boards blindly in a newer set can be frustrating and expensive. I would let a reputable repair person look at it. At least he/she can tell you what the exact problem is.
Mar 13, 2010 | Sanyo DP50747 50 in. Plasma TV
Tv wont stay on it comes on for a couple seconds then shuts back off
kc0mgp: have you had your tv serviced as of yet, or had this issue resolved? I have the exact same tv with the exact same problem?
Dec 24, 2009 | Emerson LC320EM8 32 in. LCD TV
Turns on the shuts off
I had the same exact problem!!!! If you unplug it, then plug it back in after a couple of days. You will hear a frying sound then a loud clap!!!! Solution: Replace it with a LCD.... Not worth getting fixed!!!
May 26, 2009 | Emerson DTE315 TV
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Will not turn on, but....
the arc when you plug it in is from the degause cirt operating, the fault sounds like at least a pwr supply repair $100, & or vertical + $50,and or horizontal + $150,If water is the reason.
Dec 06, 2006 | RCA 27F650T 27" TV
Nintendo Wii Console Logo
13 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
