Question about Linksys Wireless-G WRT54GS Router (e125894)
WRT54GS works fine on LAN cables but the wireless signal comes and goes. Will be working fine and suddenly you will be without wireless. Just as randomly comes back on and works until the next time it decides to go away. Might be 20 minutes or 3 hours. Never any rhyme to it. Can this be a driver problem or an inherent problem which has come up with this unit? Can the transmitter chip be replaced? I don't see any dust or anything inside the unit so I don't think it is overheating.
    Sergeant:
    Novelist:
  • 179 Answers
I don't know how old your unit is. Generally, issues that will cause intermittent connection are (1) RFI (radio frequency interference); (2) poor antenna connection; and (3) circuit degradation caused by overheating.
RFI can be caused by certain older cordless telephones (which operate in the 2.4 ghz band), or other similar wireless devices in close proximity to the router. Putting distance between them is the only viable solution (other than shutting down the offending device).
The antennas can be removed, the contacts sprayed with an electronic contact cleaner (QD Brand is available at most major hardware outlets) and reassembled which in some cases may help.
The last, and unfortunately most likely, situation is that the machine is overheating. Unfortunately (at least in my experience over the past few years) this particular router has shown a tendency to run hot and fail, although they usually last beyond warranty period. Dust doesn't have much to do with it. No, the transmitter circuitry cannot be replaced...and even if it could, it would cost you more than a new router.
It is NOT a driver problem, so don't go trying to update/reinstall drivers.
And, lastly, how far the receiving device (ie., computer) is from the router...and what is in between...can have a huge effect on the signal strength on the receiving end. Has anything changed in the environment in that respect?
Hope that is helpful.
Posted on Dec 31, 2010
Testimonial: "Thanks Firetree. I appreciate the blazing fast answer even though I was a "no payer" player. I had not thought about possible 2.4 gHz interference."
The password comes back as invalid when I just used the same password to connect my Windows based laptop and my iphone to the Wifi......
Report Trouble with Linksys router WRT54GS [Solved/Closed] johnkwit 2Posts June 16, 2008Registration date - Jun 17, 2008 11:17pm BST - Last answer on Jul 27, 2010 5:27am BST hello Hello,
I have a new Linksys router WRT54gs and a new Dell laptop.
The router works well with the cable attached but when I go to wireless
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help.
Any help would be apreciated
Jan 05, 2011 | Computers & Internet
Need passphrase---it doesn't work 192.168.1.1
When you connect a LAN cable from your computer to the Linksys then open a browser and enter the configuration URL
http://192.168.1.1
Login = admin
PW = admin
Then go to the wireless setup
The WPA or WPA2 encryption can be setup using a passphrase.
This can be any combination of words and numbers. Eg My computer1 is mad. - This passphrase is used to generate a hexadecimal encryption number. It is easier to remember a phrase than Hex numbers.
You will also need to configure the LAN card in your computer with this passphrase so it can connect to the wireless router. Once the router configuration is complete the LAN cable can removed, it is not needed for wireless connection.
For details on how to secure youe wireless network, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 15, 2010 | Linksys Wireless-G WRT54GS Router...
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
My router shows no connectivity.
Take your ethernet cable from the wan port and plug it into the lan port.
Nov 16, 2009 | Linksys Wireless-G WRT54GS Router...
How do i connect and get signal?
This is a common problem with Linksys wireless routers and primarily the WRT54G and WRT54GS. For some odd reason they all of a sudden go stupid and forgetful.
The easiest method to revive these routers is to go to the Linksys web site and get the automatic configuration download for your specific model of wireless router.
Hope this helps you
Dec 26, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS not working
  1. First you may need to check if the WLAN or Wireless light on the router is on.
  2. Try connecting your ITouch to a different wireless network.
  3. If you can borrow a wireless ready laptop from a friend, then borrow one.
  4. Check if the laptop will be able to detect a wireless signal from router.
Please update me about this matter.
Nov 16, 2008 | Linksys Wireless-G WRT54G Router
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Not staying connected
i think you have problem in your LAN port try to buy a USB LAN card 100% im sure it will gonna work.
Mar 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Linksys Wireless model # WRT54GS
It sounds like the router went bad and your need to get a new one
Mar 05, 2008 | Linksys Wireless-G WRT54GS Router...
Connecting wrt54gs to rv042 on LAN port
I would love to help you on this, however, I would need some more information. Also, this requires some advanced troubleshooting steps which cannot be dictated here. I would request you to initiate a chat session with me from the homepage and we can move forward from there. Thanks
May 10, 2007 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
325 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
