Question about Cameras
I can't figure out how to use the large screen to set my picture to take it I can only use the small viewfinder
  • 747 Answers
Not knowing the make or model of the camera you have I can only guess that there is a switch possibly lower right of the small viewfinder with the letters LCD/EVF. This would be a slider type I'm going to presume but may be a button. This switch will toggle between viewfinder and LCD
Posted on Dec 31, 2010
When I look to the viewfinder I have a blank screen
Viewfinder, screen and pictures are blank / black - Nikon ...
https://www.ifixit.com/.../Viewfinder,+screen+and+pictures+are+bla...
iFixitMay 4, 2015 - When I look through the viewfinder or at the lcd it is blank / black. Also when I take a picture and view it on my computer, the picture is blank ...
SONY ' eSupport - There is no picture or a black screen ...
https://us.en.kb.sony.com/.../there-is-no-picture-or-a-black-screen-appear...
Dec 8, 2015 - There is no picture or a black screen appears in the viewfinder or LCDwhen attempting to ... Look to see if an image can be seen in the viewfinder or LCD. IMPORTANT: Some camcorders have both a viewfinder and LCD.
There is no picture or a black screen appears in the ...
Jan 11, 2016 | Cameras
Screen is black when trying to take picture
Generally the settings have been changed from Display Mode to Viewfinder Mode. This was probably changed accidentally, but can be reverted by going into the menu under display options and changing it back to display on the small lcd screen.
Also, make sure to check that if there are connector pins that "lock" the screen into place, that both those pins and the small gold-colored strips are clean.
Jun 23, 2010 | Kodak Cameras
Camcorder will playback ,but shows no image when recording
Can you make it go while attached to a Power Adapter ? and with battery OUT, try that first. IF it works, buy a new battery for that model. Batteries can go so flat they cannot be charged, without special equipment,and even then they may not resurrect. funnily enough, leaving things without current running through them, or powering up,every few weeks, etc, can often cause a problem, strange huh?
Mar 23, 2010 | Canon MV700i Mini DV Digital Camcorder
LCD screen and small viewfinder screen go snowy than white. When I turn the camera on the LCD worked fine, when I than turn it, it was just white. Now it won't even turn on normal. I can still make...
Go to your menus, set all to factory settings or default.
Test the camera by using more of the settings, and notice how it works.
The LCD settings especially are what you want to make sure are set right...not too bright, and of course not too dim either.
Sep 25, 2009 | Canon Cameras
Blury view finder
On the left of your viewfinder you will find a small knurled wheel. By turning this wheel you adjust the diopter settings of the viewfinder. You probably accidentally moved it and didn't know it.
Aug 11, 2009 | Olympus SP-550 UZ Digital Camera
The menus keep popping up when all I want to do is shoot photos. How can I better control the display menu on the viewfinder. I'll take a picture and then the display shows up. It ruins the spontaneity of...
Could you explain in a better way your problem?
The XSi don't show the menus on the viewfinder, it only shows on the back screen.
You can shut if of by hitting the "DISP" button just at the left side of the viewfinder.
You can also enable the screen to go ON or OFF, when you go close your face to the viewfinder, so the screen will be OFF when you get close the viewfinder, and ON when you move back your face
I'm trying to figure out how the menus can ruin a picture.
Let me know more about your problem.
Jul 08, 2009 | Canon EOS Rebel XSi Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
This is not a digital camera. In order to see what you are taking a picture of, you use the optical viewfinder -- a small "window" at the top center of the back of the camera. When you can see in the viewfinder what you want the picture of, slowly press the shutter button.
Apr 15, 2008 | Canon Sure Shot 105 Zoom S 35mm Point and...
LCD kaput - anyone know of a panasonic recall?
The panasonic camcorder does not use the Sony CCD element. If the small viewfinder is showing the camera video, there's nothing wrong with the CCD imager. We have had numerous problems with the switch that controls the activation of the large LCD and the backlight inverter that powers it. When you open the LCD the small viewfinder should power down to conserve battery power. The large LCD should then illuminate, if not, shine a flashlight at the surface of the LCD and notice if the video is present, if so, the backlight or LCD harness is defective. Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | Panasonic Palmcorder PV-GS120 Mini DV...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
