Question about Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2"
How do I remove the assembly to replace the O ring driver?
How do i replace the fuel pressure regulator
Replacing fuel pressure regulator on Toyota Vitz, Yaris and Eco:
1. Remove rear seat.
2. Remove rear service hole cover.
3. Remove fuel pump and vapor pressure connector.
4. Start the engine till it stops on it own and switch the ignition to OFF.
5. Remove the tube joint clip, wrap a piece of cloth around it and pull out the main tube.
6. Pinch the fuel emission tube connector clip and pull it out.
7. Remove the 8 bolts and fuel tank vent tube set plate.
8. Remove the fuel pump assembly.
9. Remove the O ring from fuel pump assembly.
10. With help of screw driver remove the fuel pump locking plate.
11. Remove the fuel pump regulator with screw driver a bit force fully.
12. Assemble the fuel pump assembly in the reverse sequence of dis assembly.
Hope that it works. Thank you for visiting Fixya.
Feb 15, 2015 | 2000 Toyota ECHO
How to replace 2007 accord Se fuel pump?
have to drop the gas tank its located inside, once tank is down will have a metal lock ring that hold the assembly in place take a flat tip screw driver and a hammer and tap the ring around to unlock position and pull up on the metal lines should come free becare full there sometime a plastic or rubber oring/seal under try not to damage it after that remove the fuel assembly and replace with new then reverse your process to put back in
hope this helps
Aug 30, 2014 | 2004 Honda Accord
How to remove headlight housing 2001 FLSTC
To remove the headlamp housing assembly disconnect the wiring harness and then remove the bolt underneath the housing and ligt the housing off the mount.
To change headlamp bulbs:
2001 FXSTD, FXSTS and FLSTS Models
Remove the trim ring screw and then the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
unhook them from the notches in the headlamp assembly, pivot the wire retaining clip away from the bulb, replace the bulb and re-assemble all.
2001 FXST and FXSTB Models
Loosen the trim ring screw and remove the trim ring, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
FLSTC and FLSTF Models
Except for HDI motorcycles which have a Halogen bulb similar to FXST the FLSTC and FLSTF motorcycles have a sealed beam type headlamp. HDI headlamps also contain a position lamp bulb that is found under the headlamp assembly's rubber boot.
Remove the trim ring screw and then the trim ring, being careful not to bend the two tabs that hold the
top of the trim ring in place, pull the wiring connector block off from the bulb prongs, remove the rubber boot from the back of the headlamp assembly, squeeze the wire retaining clip ends to
May 17, 2014 | 2000 Harley Davidson FLSTC Heritage...
How do you change driver side headlight bulb
The headlight assembly must be removed from the vehicle in order to gain access to the bulb fixture. Open the hood and look at the headlight from the inside - you'll see a couple of plastic wingnuts that hold the assembly in. Remove wingnuts and slide assembly out. Turn plastic retainer ring on bulb to release bulb, remove and replace. Reverse procedure. Make sure you align bulb correctly for retainer to lock down or else bulb may fall out while driving.
Good luck!!
Nov 16, 2010 | 2007 Volkswagen New Beetle Coupe
Where is the FUEL PRESSURE REGULATOR
Under the upper intake manifold:
This procedure is for the CSFI system as the CMFI system uses an integral fuel pressure regulator. The CSFI uses a replacable unit mounted on the CSFI assembly.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Relieve the fuel system pressure. Refer to the fuel system relief procedure in this section.
  3. Remove the upper manifold assembly.
  4. Remove the fuel pressure regulator vacuum tube.
  5. Disassemble the fuel pressure regulator snapring retainer.
  6. Remove the fuel pressure regulator assembly and the O-rings. Discard the O-rings, filter and back-up O-rings.
To install:
  1. Lubricate the O-rings with clean engine oil and install as an assembly.
  2. Install the fuel pressure regulator, attach the vacuum tube.
  3. Install the snapring retainer.
  4. Install the upper manifold assembly.
  5. Connect the negative battery cable.
Oct 02, 2010 | 1993 Chevrolet Astro
Have 1998 safari 4.6 throttle body cannot find fuel pressure regulator
Astro, Safari 1997-2005
Fuel Pressure Regulator - Removal & Installation
    Fig. The fuel pressure regulator is retained by this clip
    Fig. Replace the O-rings whenever the fuel pressure regulator is removed
To install:
  1. Relieve the fuel system pressure.
  2. Remove the upper intake manifold assembly.
  3. Remove the fuel pressure regulator retainer clip (5).
  4. Pull and twist the fuel pressure regulator (6) in order to remove the fuel pressure regulator from the fuel pressure regulator housing using a shop towel to catch any spilled fuel.
  5. Remove the regulator seal lower O-ring (3).
  6. Remove the regulator assembly filter (2).
  7. Remove the regulator seal upper O-ring (1).
  8. Remove the regulator seal backup ring (7).
  9. Discard the O-rings.
    Fig. Exploded view of throttle body assembly (click for zoom)
To install:
NOTE If the fuel pressure regulator is to be reinstalled, inspect the filter screen for contamination. If the filter screen is contaminated, replace the regulator.
  1. Lubricate the new O-rings with clean engine oil.
  2. Install the regulator seal backup ring (7).
  3. Install the regulator seal upper O-ring (1).
  4. Install the regulator assembly filter (2).
  5. Install the regulator seal lower O-ring (3).
  6. Assemble the regulator (6) with the vacuum tube pointing down into the regulator retainer clip.
  7. Install the fuel pressure regulator retainer clip (5).
  8. Install the upper manifold assembly.
  9. Connect the negative battery cable.
  10. Inspect for leaks.
    1. Turn the ignition ON , with the engine OFF , for 2 seconds.
    2. Turn the ignition OFF for 10 seconds.
    3. Turn the ignition ON , with the engine OFF .
    4. Inspect for fuel leaks.
  11. Install the engine cover.
Hope helps with this (remember comment and rated this).
Aug 05, 2010 | GMC Safari Cars & Trucks
How do i remove the rotor after removing calipar
remove centre cap bolts, remove then circlip in centre, remove that section, then look for 3 philips head screws in "holey" lock ring and remove screws(sometimes need to do with impact driver), remove lock ring after undoing screws, then undo silver ring (anti-clockwise) by putting philips screw driver in holes of silver ring with lines in it and turning, then remove disc and hub as assembly (hub does separate if you undo the 17mm bolts that hold the disc to the hub, must do up this ring firm then back off and then do up the old feel method way. align a line in silver ring with top notch of centre threaded shaft that ring goes on, to one of the sides then when you put "holey" ring back on you can get the lock screws into silver ring.
Aug 04, 2010 | 1999 Isuzu Trooper
Myn60fn is leaking from around the trigger, do I have to take the whole thing apart to replace the o rings or do I just drive out the spring clips?
You will need to remove the trigger before driving out the roll pin. After you remove the trigger and roll pin, place a rag over the trigger, remove your hand from the area, and briefly hook up your air line. (Clean your soiled pants after this part) You will hear a loud pop and the trigger assembly is going to come out quickly. If you are not prepared for this it will scare the **** out of you. Then once you have the trigger assembly out you can push the two retaining pins on the assembly out and remove the inner workings of the trigger. One note of caution. The ring you are trying to replace is a hard half moon looking ring that Bostitch doesn''t sell separately. You may see it in pieces when you take this assembly apart, or you may not. Sometimes it crumbles and comes out of the trigger exhaust. You can try to match up an oring to sit in there, but from experience it is much easier and less costly to just order the whole trigger valve. Hope this helps.
Sep 29, 2009 | Stanley Bostitch N88rh Framing Nailer...
Driver light out how to replace bulb need special tools?
Headlight Bulb Removal & Installation To Remove:
  1. Disconnect and isolate the negative battery cable.
  2. Remove the headlight assembly mounting screws.
  3. Pull the assembly forward and disconnect the bulb connector.
  4. Turn the bulb retainer ring counterclockwise and remove the bulb from the headlight assembly.
To Install:
NOTE: Do not handle the glass portion of the bulb with your bare fingers.
  1. Install the bulb in the headlight assembly.
  2. Install the retainer ring.
  3. Connect the connector to the bulb.
  4. Install the headlight assembly in the vehicle.
No special tools required.
Jun 24, 2009 | 2004 Dodge Caravan
Drivers side wheel bearing
When you buy the replacement wheel bearing it comes as a sealed unit. This is why they're called hub assemblies.
Jul 03, 2008 | 2000 Mazda 626
Senco FP18 FinishPro 18 - Gauge Brad Nailer, 5/8" - 2" Logo
76 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Trippy Tripp
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
