My a.c. is in heat mode and its on and off and I switch the thermostat off but the ac still runing on and off
  • 111 Answers
Easy fix is pull dissconnect on ac compressor.Thats the big box outside with fan in it.should have a box next to it where you can pull out handle to cut power.if not check fise box for doubble breaker labled ac.Not a heat pump is it?if it is thenthats a different problem .other easy fix is go into furnace and dissconect wire running to ac.The small one.Finding the cause is pretty advanced trouble shooting
Posted on Dec 31, 2010
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
Why contactor on heat pump will not energize heat mode?
Heat pump and AC are basically working the same principle. When you turn on the heat pump is just like to turn on the AC. The main contactor will energize to turn on the compressor. The only difference is the 3 way valve, either switching to AC mode or heat mode. It is the most commom problem for heat pump. Check the thermostat wires for heat mode and defrost control.
Feb 05, 2015 | Heating & Cooling
Trying to hook up haier heat pump as cond. only. when in ac mode system is in heat mode. either iam missing something, not right digrams
Hello RRIKE The reversing valve is not energized.At the thermostat check the "O" termnal is used.It switches the valve over to cooling during a demand.
Aug 25, 2010 | Heating & Cooling
No heat in car blower works,thermostat was changed coolant level good car runs hot
problem could be in the mode switch + check fuse to heater and ac mode switch.if blown your air door wont open and let heat enter inside car.if fuse look good you could have faulty mode switch.if you have climate control if you have a bad in vechicle sensor that will effect air door to open let heat in.this problem would be best for dealership.if dealing with climate control units.you need a quick fix.too cold outside not to have heat in car.
Dec 14, 2009 | 2003 Nissan Altima
Over heat with ac
Replace your thermostat.
Jun 10, 2009 | 1995 Jeep Grand Cherokee
Honeywell thermostat
make sure not turned on @ tstat to man ,also were you in the heat or cool mode when this occured .
Oct 26, 2008 | Honeywell Programmable Thermostat Heater
Ac problems (over heating)
Did you tried to change the gas? i had same problems but it was the gas, change it.
Jun 17, 2008 | 1992 Mazda Protege
Heating & AC thermostat problem
It could be running in a "programmed mode" if it has the capabilities. You could exit from the programmed mode
Mar 29, 2008 | Computers & Internet
Question
a programable thermastst has different modes. in auto it can deside whether to apply heat or cooling. ac air coditioning. or you are in ac mode, but should notice the ac unit comming on. if no ac unit then of corese it won't come on :)
Jan 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
