underneath the dash where the steering wheel colume is you will see the top end of the brake petal, and attached in there you will see a connection that turns the brake light off when the pedal is released by pushing it in, there are rubber attachments on that button like piece that goes in and out, which turns the brake lite off and lets in come on, when the brake is pushed down. Replace them, just tell the people at the parts place what you need and they will know what it is. Good luck. Don Carroll.
Your brake switch is just hung up. it is located directly above the brake petal and is attached to the petal bracket-use a flashlight and get down low enough to see up under the dash where your brake petal is, it will be hooked onto the petal bracket-just move it, it is probably just mis-aligned.
check the brake switch located just above the brake petal it is probably hung up-you will need a flashlight to see it, and it is attached to the brake petal linkage.
your master cylinder leaking onto firewall? do you have brake fluid coming into the car around under steering wheel? if so you have bad master cylinder, if on a hill you hold brake and petal moves down under foot pressure the master cylinder is bad
It seems that you have a huge problem. This wheel only connects to a 15 pin game port, newer computers do not have the game port. You have to buy a 15 pin to USB converter, about $30.
