Question about Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop
I'm running Windows Vista Business with a Belkin PlugNPlay router as host. My wife's networked computer is running Windows 7. In my network/sharing center I'm unable to change the network from public to private (its grey'd out) and, after 8 months of intermittent connection issues from the W7 computer, now it goes to an IP4 address that is unrecognizable and I can no longer see it on the network and it won't connect. Any advice?
    Brigadier General:
  • 8,909 Answers
Running the risk of a thick ear from the wife, I would dismantle and uninstall the network. Reboot your computer and set it up again then add your wifes computer without letting 7 change the settings.
Posted on Dec 31, 2010
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Tip
Network Windows 7 with Xp and Vista
Windows 7 includes a new way to share data between all computers in the house with the Residential Group. But only when computers running Windows 7 may join the Group residential and enjoy the new features of sharing, playing multimedia files remotely, etc.. If you have computers running Windows XP or Windows Vista networking with Windows 7, you can still share your files and printers in Windows 7 "old" by following the instructions in this case practice. Below are the steps to do the same.
Check the workgroup:
To be a network, your computers with XP, Vista and Windows 7 should be part of the same workgroup.
Click the Start button. Right-click Computer (My Computer in XP) and click Properties.
In the Settings area of the computer name, verify the name of the working group. The default name is WORKGROUP but you can customize it by clicking the Change Settings button.
Make sure it is the same on other machines on the network. Under XP, the information is in the Computer Name tab.
Enable Sharing:
To enable sharing in Windows 7, you must change the settings of the Network and Sharing Center.
Click Start, then Control Panel.
Click Network and Internet and then click Network and Sharing Center.
In the left column, click Change sharing settings advanced.
Verify that the options Enable network discovery, Enable file sharing and printer sharing and Enable so that anyone with network access can read and write are checked.
Click Save Changes.
on May 19, 2010 | Computers & Internet
Tip
Virtual Server / Port Forwarding does not work from within the Local Network
When you use port forwarding in Virtual Servers and try to test it from within the local network, it may fail. When for example, port 80 is forwarded to a web server in the local network, you may get the router's home page instead of the web server's one or you may get nothing at all. When you try to use the server from outside the local network it will work fine though.
This can happen when you try to access the router's WAN IP address from within the local network. In order for port forwarding to work from within the local network, the router needs to support a feature called NAT loopback. This is not a part of the specification of Belkin routers and modem-routers, so most of them will not have the feature, and if a router does have it, it is not supported.
In order to use the server from within the LAN, you can address it by its internal LAN IP address (e.g. 192.168.2.101).
If the WAN IP address has a DNS host name associated with it, such as www.example.com, and you need to use that name to connect to the server, you can do so by associating the name to the local IP address in the hosts file (a file called hosts with no extension). This file lists IP addresses and host names and is used before actual DNS lookups are done. You can add lines to the hosts file using a text editor like Notepad on Windows. The lines look like:
192.168.2.101 www.example.com www.otherdomain.com # comment
The lines contain an IP address and one or more host names separated by white space. Anything that follows a hash sign is a comment and will be ignored. You will need to change the hosts file on all machines in the LAN that need access to the server.
On Windows, the hosts file can be found in C:\Windows\System32\Drivers\Etc on Windows XP, Vista and Windows 7, in C:\WinNT\System32\Drivers\Etc on Windows 2000, and in C:\Windows on Windows 98 and ME. You need to have administrator rights to edit the file; on Windows Vista and Windows 7 you need to run Notepad as administrator.
on May 05, 2010 | Computers & Internet
I have a new Belkin Play router and when I watch a video online (like a you tube video) it pops up and says that my Belkin router password may have changed. It then asks me to re-enter my password and then...
= The Belkin Router Utility Might Not have Been Installed Properly.
> To Get Rid of this Issue 1st of all Disable or Uninstall Belkin Router Utility.
- Goto Start > Control Panel > Uninstall Programs
- Select Belkin Router Manager Utility & Uninstall It.
> Now you Have to Remove preferred Networks & Join the wireless Network.
Steps to Remove Preferred Network & Joining the Network
- Windows XP
- Goto Start > Control Panel > Network Connections > Right Click on Wireless Network Connection > Click on Properties > Select Wireless Networks Tab > Under Preferred Networks Box > Select your Wireless Network Name & Click on Remove Button. Close the window
- Right Click on Wireless Network Connection & Click on View Available wireless Networks.
- Wireless Network Connection window will appear. Select the network you wish to connect and click Connect. It will ask you For a Network Key Type in your Password.
> Windows Vista & Windows 7
- Go to Control Panel > Network and Sharing Center > Click on Manage wireless networks Right click on your wireless Network > Click on Remove Network .
> Connecting to a Wireless Network.
- Goto Network & Sharing Center Click Connect to
- Select your wireless network & click Connect
- It will ask you For a Security Key Type in your Password.
( If you are unable to go online you can try power cycling the router for about 15 seconds. If Even Power cycling doesn't work that means you have to disable WPS option on the Belkin router)
Mar 08, 2011 | Belkin Computers & Internet
Belkin N+N storage router doesn't work wirelessly
Hi, I had something like that with my Belkin Router N+N with USB F6D6230-4 V1, only I had a configuration wit a wired XP pc, Wireless XP and Wireless Vista. With both XP pc’s it was really plug and play, but with the Vista pc I had some problems to access the on the router connected USB drive. The Vista pc was connected to the network, and had Inet access. Other shared (network) drives were accessible on the Vista pc.
The first thing I tried was if I could access the drive trough its IP address, (\\routerIP in my case \\192.168.2.1), and I did get a question for a username and password. The only thing is that I tried all the regular names like Admin, Administrator, and so on, with my password but I did not get access.
On the internet there was no help to find for this model router on the Belkin websites (diverent country’s), the data on the Belkin websites is out of date, there is no support to find for new models. ………. So finely I did took the phone and did call the support desk…
Solution to my problem:
The problem seems to be in the Belkin storage manager program, that program works not correct under Vista. When I enter the routers IP and use the username “guest” without a password, it get access to it from my Vista pc. The follow thing I did was press the right mouse button on the drive, and press on “make connection” So..
\\RouterIP
Username : guest
Password : none
Hope, that this is also the solution to your problem.
Greatings
Martin,
The Netherlands.
Feb 23, 2010 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
Can't see other computers in network
first,check properties of LAN of all computer...then check the FILE/PRINTER SHARING
second,OFF all windows firewall..
now,open your windows explorer to view other computers... jaz type in the address bar \\<computer name of ip address> of other computer you want to view
Oct 28, 2009 | Belkin Computers & Internet
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Wireless network between vista & xp
Open Windows Explorer, and then locate the drive or folder you want to share. Right-click the drive, and then click Sharing and Security. To open Windows Explorer, click Start, point to All Programs, point to Accessories, and then click Windows Explorer. To change the name of your folder on the network, type a new name for your folder in the Share name text box. This will not change the name of the folder on your computer. To allow other users to change the files in your shared folder, select the Allow other users to change my files check box.
Oct 06, 2007 | Computers & Internet
Microsoft Windows Vista Business DVD 66J-02289-oem PC Desktop Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
