Question about Maytag Dryers
My Maytag Dependable Care dryer, model MDE9206AYW has begun sueaking very loudly when running. The noise sounds like it may be a rubbing-type of a noise, or possibly a belt. I have not tried to take anything apart yet, but believe I could correct the problem if I had a repair manual for the dryer. The dryer still works fine, but the noise gives me the impression that I should not use it the problem is corrected.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.Here is a link to the part in case you need it.
Posted on Dec 31, 2010
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
Loud Rubbing noise from my Maytag Performa Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 20, 2010 | Maytag Dryers
Have a Maytag Dependable Care Dryer that is about
you have to take it apart,it could be a roller or the belt pulley but you have to pull the drum to do this and you need a tool to remove the clip that holds the roller on,it's just a pair of needle nose plyers with like pointy tips on it to fit into the clip to pop it off,that's called a jesus clip if you drop it you'll see why it's called that lol,you can go on utube and you can find a video on how to take your dryer apart.i think the part number is 12001541 for the roller
Feb 07, 2018 | Maytag MDE308DAYW Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
I hit the start button on my maytag MDE9206AYW and it don't start
Sounds like the motor is going bad. If you keep going like that eventually you will hear a loud noise, and it won't even start.
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag Dependable Care Quiet Plus 2 /gas dryier
Magyar quiet puls 2, does not heat, have to run 3 times to dry out. Is it usual?
Jul 28, 2009 | Maytag Dryers
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Dryers Logo
317 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
