Question about Cameras
I have a Pentax K10d. Was working perfectly. Now when I put the lens and see trough the visor is dark is like the apertur doesnt open and is in f 22 all the time.}
  • margammsr Jan 03, 2011
    The solution you gave me has not for a DSLR camera. THe pentax K10D is a camera that you can change lenses. The problem is when you change the lens the shutter keeps close instead of open so you can see through the visor clearly.
    best
  • 10,319 Answers
The camera has tiny motors that drive most mechanics such as the functions of the lens, shutter, and other items. Each one runs off a separate capacitor which stores the correct voltage needed to run these motors. If one of these capacitors gets a hairline crack in the side the voltage leaks away. In other words not enough voltage can be stored in it to be a useful capacitor.You can check for an estimate for repairs through keh.com in Georgia which is a highly rated camera shop
Posted on Jan 07, 2011
  • 3,083 Answers
It sounds like the shutter is stuck. This is along the lines of a lens error, and the following web blog describes things you can try to fix the problem:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Check that all your settings are set to an automatic mode, also.
The first thing to try is to spray some compressed air into the lens assembly, while it's extended ($4 at Walmart). Second thing to try to to gently "bump" the camera on the palm of one hand, in the hope of freeing it up.
If none of these suggestions works, contact Pentax to see what it would cost to fix it. Here's their site:
http://www.pentaximaging.com/support/
You could also run it into a local camera repair shop, after seeing how much Pentax wants for servicing, and see what they would do it for. Second opinions never hurt.
Good luck, and hope this helps.
Posted on Jan 02, 2011
I have a Pentax K10D from the time they were first sold. I have not installed any firmware as not very technically talented. Have recently bought a Sigma 120-400 zoom.( no zooms of this range from...
Only Pentax DA and FA J lenses and D FA/FA/F/A lenses having an "A" position on the aperture ring can be used with this camera.
The lens you have is HSM DG
Jun 10, 2017 | Pentax Cameras
K100D AF/MF SWITCH STUCK IN AF
Can you be more clear with your problem . When you are facing this problem ?
Have you done basic troubleshooting techniques like replacing new batteries, gentle tapping on camera
Oct 04, 2008 | Cameras
Slow to autofocus and sometimes will not focus at all with my pentax k10d slr digital camera with a pentax 16-50 da lens. when I switch to manual focus the camera works fine.
Clean the contacts on the camera body and the lens where they connect with a cotton swab lightly dampened with rubbing alcohol.
Sep 27, 2009 | Pentax K10D Digital Camera
New SMCP-FA 50 1.4 will not work on my K100D Super or K10D
You are probably right - it sounds like it is not connecting right - I would take it and the camera to the store and check out another lens!
Dec 29, 2008 | Pentax Normal SMCP-FA 50mm f/1.4 Autofocus...
Err message on Nikon 75 after taking a picture
Here's a link to the N75 / F75 user guide. The troubleshooting section / lens compatibility area might point to the problem. If the viewfinder is dark, the mirror is likely stuck in the UP position. This is usually due to a lens compatibilty issue, or the fact that the lens is not set to its smallest aperture (ie 22). The camera needs that to control the full range of aperture openings
Dec 07, 2008 | Nikon N75 35mm SLR Camera
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
SHUTTER HESITATION
May be the problem is with the lens. Put a maximum aperture say f 22 then press the shutter, if the leaves of the diaphragm shuts and opens fast ten your lens is OK
.If there is any oily appearance between the leaves of the diaphragm then it should be cleaned.
Mar 13, 2008 | Pentax ME Super 35mm SLR Camera
Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Feb 12, 2008 | Pentax K10D Body Only Digital Camera
Adjusting the f stop
Lock the aperture in F 22. This will get rid of FEE. Now control the aperture settings from the body ( control infront of shutter release )
Aug 07, 2007 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Cameras Logo
14 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
