Question about Samsung LN-S3292D Television
Black Screen I checked the connections.....has sound but no picture black even when I push menu button or source
    Master:
  • 691 Answers
This could be the t-conn board in the back middle top of screen, it's under a metal plate.
Posted on Dec 31, 2010
Lumix DMCTZ2 Problems
DFid you try to shoot a picture, even not seeing what you are shooting? Try it. Then ale check what happens if you press the display button, (left one under the Menu / set buttons)
Let me know how you and your camera are doing now.
Jul 07, 2014 | Cameras
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
My plasma t.v model lnr328wx comes on with sound but no picture.
I don't know if your using an antenna or other source but one quick test to see if your TV can display is to push the display or menu function. If your screen stays black then your TV has a problem and needs serviced. If your screen shows a menu then you may have a problem with the source video.
Try to elaborate more on your hook-up, it can be most helpful in solving display problems.
Sep 11, 2010 | Samsung LNR238W 23 in. LCD Television
My screan is black but I have sound. my small chld
It sounds like you have an inverter problem inside the set. You should be able to see the menu. There is nothing in it to totally knock the display out.
Oct 14, 2009 | Insignia IS-LCDTV32 32 in. Television
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
No picture
It sounds like the backlight is out. If you can see a faint image that changes then this is the case. You either need to send in for repair or replace. It can if you are lucky be a connection. You can try removing the video cable and try another source or cable.
Jul 09, 2009 | Samsung HP-T5064 50 in. Plasma HDTV
Camera Screen black
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
Jul 11, 2017 | Nikon COOLPIX S5 Digital Camera
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Televison & Video Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
