Question about Cobra 25 WX-NW-ST 40-Channels Base CB Radio
I CANNOT TRANSMIT - Cobra 25 WX-NW-ST 40-Channels Base CB Radio
    Problem Solver:
  • 44 Answers
1st check mic then coxial /antinna ground/then if still haveing probblem check to see if SWR is set to antinna
Posted on Jan 03, 2011
Yaesu 3100 transmit problems
There are several reasons you may not be able to transmit with the FTM-3100R:
1) Your antenna is not matched to the frequency of use and presents a high SWR. The 3100 protects itself from high SWR by refusing to transmit
2) You have somehow enabled the busy-channel-lockout feature in the setup menu, and you are operating with an open squelch
3) Your DC power supply voltage is too low to support transmit current
4) You are transmitting with too low a power setting and the receiver cannot hear you
5) You are attempting to transmit to a repeater that uses a CTCSS squelch tone, and you do not have the proper squelch tone configured
Both of the LEDs to the left of the display should turn red to indicate you are transmitting. If both LEDs turn red, your problem is likely either #4 or #5.
May 21, 2017 | Yaesu Radio Communications
Kenwood Protalk tk-3200U8P will receive, but not transmit. When talk button is push a loud beep will sound. Any suggestions?
Assuming it is programmed correctly, it is a weak, undercharged or bad battery. Transmit takes a lot more power than receive. A beep or no transmit, even if the Transmit light comes on can still mean the battery condition described.
Feb 11, 2015 | Kenwood Radio Communications
Kenwood tm-281a transmitting but no one can hear me.
How is your antenna? Do you have another 2 M radio? Try feeding a dummy load and listening on another radio nearby. Look at the display when you transmit. Does it show the right frequency? If you have the offset wrong and it is taking you outside the band, it will likely not transmit. Do you have a power meter? Does the rig's current drain go up when you try to transmit? (Does the power supply keep the voltage up when you try to transmit?) Supply voltage dropping will cause the rig to NOT actually transmit.
Nov 14, 2014 | Radio Communications
Radio will not send
It is possible your Code for transmit is different than your Code for receive. Cobra makes so many models, you are not giving enough information. Also, Transmit takes a LOT of power, so even if everything is setup, if your batts are weak or old, the radio will receive, but not transmit. Also check your antenna, make sure it is tight and NEVER transmit without an antenna. Yes, all lights will work even with old batteries.
Nov 10, 2013 | Cobra Radio Communications
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
How to fix cobra 29 lx that will receive but not transmit?
your final could be blown,thus no transmit . if you change it make sure you change the driver also and retune that portion of the radio.
Jan 17, 2013 | Cobra 29 Lx Full-featured Cb Radio
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
Motorola spectra ta9fw+078w will not transmit
There are a variety of reasons for your Spectra to fail to transmit. A few items to check would be:
1) Power to the radio. If enough power is not present, transmit is the first thing to usually fail.
2) Check your hand mic. This is a common failure part on a mobile radio.
3) Check your antenna and connections. Coax ages over time, and is not forgiving of creases or bends. Also, if your antenna stinger has become loose over time, it will effect your transmit.
Beyond the above mentioned items, most anything further would require repair of the component board of the radio.
Best regards.
Mar 04, 2012 | Radio Communications
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
CA12CD Plantronics will not transmit on Centracom Series 2 consol
The headset you bought will work with the Centracom Gold Elite but the older Series II may not work. Have you tried Plantronics assistance. They are very helpful and will support the product.
Apr 10, 2009 | Radio Communications
Cobra 25 WX-NW-ST 40-Channels Base CB Radio Logo
43 people viewed this question
Top Cobra Radio Communications Experts
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
