Question about Rule Pool Cover Pump Strainer
My Rule Pool Cover Pump is less than a year old, been used 5 times and now will not pump. Is there a check list or reset I can try.
    President:
  • Rule Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Sorry to hear you are having trouble with the pump...Thanks to www.automaticpoolcovers.com for pulling this rule warranty information together. They sell many of these with the pool cover systems and their site tells you all you need to know about dealing with Rule warranty issues. You can find that information at:
http://www.automaticpoolcovers.net/pdfs_new/Rule%20Pump%20Warranty.pdf
Or Rule direct at www.rule-industries.com.
You may be interested in knowing they warranty the pumps for 3 years.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Dec 31, 2010
How do I get a replacement pump
go to buy pool parts on line dot com they have them
Sep 14, 2014 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Rule pool cover pump
it is contact rule also theres a date code burned on the side they give it a 3 year warranty
Jan 11, 2013 | Rule 1800 H53SP-24 Swimming Pool Cover...
Pump does not turn on when base is covered with water
Sorry to hear you are having trouble with the pump. Unfortunately there is no reset or other means of restoring your pump to operating condition. If the unit is out of warranty there is no cost effective means to get parts or to have it repaired.
John
Mar 10, 2011 | Rule Pool Cover Pump, Sump, Submersible,...
Had ice on cover and it stopped running only 3 yrs old
John
Feb 06, 2011 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Pump is not working. installed about 4 months ago. purchased pump 07/29/2010.
John
Jan 03, 2011 | Rule 1800 H53SP-24 Swimming Pool Cover...
! year old, worked begining of wint. season. Now water on cover. No ice in hose, no noise from pump, have power at outlete. Last Rule lasted 3 years, this one 1 year. Is it time to look for an other...
John
Dec 14, 2010 | Rule 1800 H53SP-24 Swimming Pool Cover...
We have a new Rule 1800 pool cover pump, which sits on a small tarp in the center of the cover ---- since our pool is surrounded by trees this makes it easier to get the leaves. In a wind storm the tarp...
John
Nov 17, 2010 | Rule 1800 Pool Cover Pump With Leaf...
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Rule Pool Cover Pump Strainer Logo
157 people viewed this question
Top Rule Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Rule Pool and Spa Expert? Answer questions, earn points and help others
