Question about Maytag Dryers
I have a commercial gas dryer model #mdg16fdaww. when you turn it on it everything works fine, but after 15 seconds the gas and the igniter cut out but it keeps spinning. is it a sensor?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
It is either the "high limit thermostat" or the "flame sensor". Check the thermostat for continuity with a multimeter to see if it is good. Here is a link to the thermostat in case you need it. Here is the link to the flame sensor in case you need that.
Posted on Dec 31, 2010
Testimonial: "YOU ARE THE BEST"
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My gas dryer burner does not heat. The igniter does not glow even to permit the gas valve to turn on. Everything else works and checks out being good, such as the thermostats, igniter, flame sensor. ...
You could check the igniter by testing to see if 120 volts is at the wiring the igniter plugs into, if 120 vac at that plug the igniter is bad Also need to check THERMAL FUSE,in addation to thermostat,on electric dryers if thermal fuse is out it cuts circuit to motor, on many brand dryers if thermal fuse bad on GAS dryer it cuts circuit to igniter
Aug 12, 2011 | Dryers
When the dryer starts it makes a quick grinding noise like it is having trouble starting. After only 1 second that noise goes away and the dryer appears to be working fine. It will stay running anywhere...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Mar 09, 2011 | Whirlpool LER4634J Electric Dryer
Igniter won't glow
I am assuming that everything works OK except you have no heat?
When you turn on dryer listen for gas valve to click(this may take a few seconds).If you don't have a click then the gas valve my be bad or it is not getting power.
Dryer has to be running to check for power only experienced persons should perform machine running power tests.
Let me know If I can do anything else to help.
Mar 20, 2010 | Whirlpool LGR5636L Gas Dryer
Gas Dryer igniter glows but does not ignite
If the igniter goes on but only cycles off you have a bad solenoid coil on the valve you can pick them up as a set at a local parts supply shouldn't be more than $25
Sep 04, 2009 | GE DDC4500S Gas Commercial Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Nov 02, 2008 | Whirlpool Dryers
Dryers Logo
109 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
