Water does not shut off, even when unplugged.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You need to replace the "water inlet valve" on the machine.
Posted on Dec 31, 2010
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
Water dont shut off
Sounds like a faulty Solonoid valve more so since it still happens with the machine unplugged. Not too expensive repair new part to buy around 15 pounds.Not sure in dollars.
Jun 11, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Water will not shut off after starting
If water keeps running even if the unit is unplugged than the water solenoid valve has become defective.
if the water stops when power is off than there is a problem with either the timer or the fill switch. My bet is on the timer.
Always be careful when opening the top cover. you will be exposing wires. power must be turned off at the breaker or the unit unplugged.
Jan 03, 2014 | Jet Tech Systems X-35C Dishwasher
G.E. Profile washer water wont shut off.
The valve in the machine is stuck open. It's not a hard part to replace if you can figure out how to get into the machine but expect it to be a $200 job if you have to call someone out for it.
Sep 03, 2012 | GE Washing Machines
Have a top loader Admiral which has a shut off problem: cold water will not shut off even when unplugged...figure it's the cold water selonoid.
Yes exactly the problem w/power off and it continues to fill it's defiently the solonoid valve
Gene
Aug 04, 2011 | Admiral Washing Machines
If I choose to have the water full to either large or even a medium level. It keeps feeling up and won't turn off. keeps running water. Why?
If water won't shut off even if you unplug the washer, then the water valve is likely stuck and will need to be replaced. If the water shuts off when water level switch is on low, but overflows when set on medium or high, it is more often the water level switch itself. Before replacing, be sure the tube going to the side of the tub is clear and not kinked. Remove the tube from the switch and blow thru it, reattach and try filling again. If it works, you should be ok, if not then replace water level switch.
Jan 18, 2011 | Whirlpool Washing Machines
My Asko Front load washer model W6021 Prewash
hi you need to replace the inlet valve,take off the top panel and you will see the valve behind the soap drawer with the black hoses.you can get a book from asko.com.au
Jun 15, 2010 | Asko W6021 Front Load Washer
Water stays on constantly without shutting off even though it is full of ice.
Water solenoid is bad and needs replacement. Unplug it and see if it still fills. If yes it's bad. If no, you have a bad timer.
Mar 01, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Water will not shut off, continues to fill
does the water run when you unplug the machine? if so then you have a bad fill valve,
Nov 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
