Question about Watches
I have a Bulova three display watch and have recently change the batteries but now I don't know how to set the watch to time, date, etc. Can anyone help me. The watch is 5 years old so I can't find the manual anywhere. The model number is C877569
  • 29 Answers
SOURCE: Setting time on Seiko watch 7N43
Mike 1935 if your watch has hands only & no digital display the crown where you set the watch pulls out half a click to set the date and should pull out a little further to set the time try that.
bjbc I am assuming your seiko watch is a digital watch. Try holding in the top rt button if its the watch I think it is it should change to 12yr time.
Posted on Mar 10, 2008
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
SOURCE: how to set time on a bulova marine star 96C30
Found the manual! Here's the link: http://www.bulova.com/dynamic_repository/instructions/581.pdf
Posted on Mar 04, 2009
escapement
  • 2334 Answers
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
Posted on Mar 14, 2009
  • 79 Answers
SOURCE: Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
Posted on May 15, 2009
I have a mans accutron bulova watch serial number H 963884 look for info year value
Value information here
https://www.google.ca/search?rls=com.microsoft:en-CA:IE-ContextMenu&biw=1438&bih=677&q=bulova+accutron+serial+numbers&sa=X&sqi=2&ved=0ahUKEwjM14mTz7PQAhUT4mMKHb7LB3YQ1QIIZCgB
Determining the Date of a Bulova Watch For purposes of assigning a date, Bulova watches break down nicely into three basic groups: 1) pre-1926, 2) 1926 through 1949, and 3) 1950 and beyond. Those three date ranges are differentiated by the presence or absence of certain case and movement markings as well as the nature of any such markings, as explained below.
In general, for all time periods, it is important to understand that Bulova watches never provide an obvious date of manufacture anywhere on the watch. Rather, the date must be "de-coded" using symbols, serial numbers, and two-character codes placed on various parts of the watch. These codes and the manner in which they should be interpreted is the subject of this article.
Many observers of Bulova watches are confused by the sometimes seen patent dates stamped on the inside of some Bulova watch cases, and they misinterpret such dates as the time of manufacture. In point of fact, those patent dates apply only to certain aspects of the case design and indicate only when those general designs were patented. Those designs were used on many watches produced over a number of years, and the applicable patent date in no way indicates when any particular watch was produced. Below are images showing the two patent dates that often cause confusion.
Read LOTS more HERE: http://www.watchophilia.com/general-information/determining-the-date-of-a-watch/
accutron bulova Google Search
Nov 19, 2016 | Bulova Watches
I purchased a Cote d' Azur watch & necklace set on a cruise ship recently, and can't seem to set the other three functions on the watch. There is only one pin but there are three addtional...
One of the dials should be seconds so you won't be setting that, the other two should be day and date, when you pull the stem and crown all the way out you can set the time there is a halfway setting ( pull the stem halfway out) if you turn one way it's the day of the week the other way is the date. Hope this helps! Also what appears to be a second hand on the dial a lot of times is actually a stopwatch.
Sep 01, 2011 | Bulova Watch
I have a tonino lamborghini watch and cant figure out how to set the time
The stainless steel band broke on my Tonino Lamborghini watch. Can anyone tell me how and where to get a new band? Or even a replacement link for mine?
Jan 07, 2011 | Bulova Watch
I'm tryng to set the date without changing the day and time. I've tried to just pull the pin out half way but its not working. How do I do this? My watch has three dials on the face - 1)date, 2) day and 3)...
mcdevito75 here, It takes practice, the crown does have 2 positions, slip a fingernail just under the crown and lift to it"s first position this will allow you to change the DATE (number) once you get the correct Date, push tje crown back in, NOW! pull the crown out to set the DAY itself and the time. On some watches the crowns first position allows both the day and date to be changed by turning the crown in it"s first position clock wise and counter clock wise.
Jul 04, 2010 | Bulova Watch
GB743 CHANGE DATE
mcdevito75 here, Your Bulova watch should have a 2 position crown (winder), carefully lift the crown to it"s first position, this should allow you to change the DAY, once done pull crown out to set the time, keep turning the hans till you get the right DATE (number) now set the correct time and your done.
Jul 01, 2010 | Bulova Watch
Bought watch without instruction on how to set the alarm function
It is the digital watch, and I do not know how to set the time and date for it and also how to change the display
Jul 17, 2009 | Bulova Watch
Breo Roam Sports watch - No Instructions
hey, know it's a while since you posted and you may not need it anymore, only saw this yesterday looking for an answer myself and couldn't find one any where, however just figured it out.
you need some thing with quite a small point like a fairly sharp pencil to depress the buttons fully. just pressing the M button will display the date, to adjust the date and time press the A button, first press allows you to change the month, second press the date, third press the hour and fourth press the minute. when you are on the one you want to change use the M button to scroll through the numbers. hope this is helpful.
Mar 08, 2009 | Bulova Watch
Watches Logo
190 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
